poor man type r
Old May 26, 2003 | 07:12 AM
jeremy.'s Avatar
Default poor man type r
tried searching but all the prev threads are gone. can anyone give me any info and stats. how much to the flywheel and wheel does it put down? how much does a type r put down? anyone have any other links? thanks
Old May 26, 2003 | 08:26 AM
dfoxengr's Avatar
Default Re: poor man type r (ek_jeremy)
search "poor mans r" that in the archived topics...
Old May 26, 2003 | 08:46 AM
jeremy.'s Avatar
Default Re: poor man type r (hybridvteceg)
i don't see the archieved topics???
Old May 26, 2003 | 08:55 AM
patdemps's Avatar
to my knowledge the type r puts 195 hp to the flywheel......
carpoint.com has car specs. Im sure if you do a search that its everywhere
Just to let you know......it only matters how much you put to the wheels bud
Old May 26, 2003 | 09:14 AM
.RJ's Avatar
.RJ
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ek_jeremy &raquo;</TD></TR><TR><TD CLASS="quote">i don't see the archieved topics???</TD></TR></TABLE>
Old May 26, 2003 | 09:15 AM
dfoxengr's Avatar
Default Re: poor man type r (.RJ)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by .RJ &raquo;</TD></TR><TR><TD CLASS="quote">
ahahahahahahaa
Old May 26, 2003 | 09:17 AM
jeremy.'s Avatar
wow gee golly thanks!!!
Old May 26, 2003 | 10:12 AM
K20  EG's Avatar
Default Re: (ek_jeremy)
dayum whatta sweetheart
Old May 26, 2003 | 10:24 AM
blah13's Avatar
Default Re: (B20---Vtec)
I dont think the arrow is big enough and this needs to be sticky.
Old May 26, 2003 | 11:05 AM
MikeSarr_GSR's Avatar
Default Re: (blah13)
power to the wheels is one thing, how the car accelerates is another.
mating an engine that breathes and pulls under load like the ITR does
is one thing. gearing is another... you could have ITR power with
GSR gears and still get walked by the top of third gear. dont worry
about putting alot of money in the GSR motor, you dont need to.
I assume you have a GSR.
I would suggest:
replace tune up parts
valve adjustment to stock spec
cam gears
skunk2 intake manifold
wait on cams GSRs work fine for now, they can be dyno tuned
ITR Throttle body
hondata tuning
Intake, Header, Exhaust (comptech sells good stuff, you can get deals now)
GSR tranny rebuild with ITR 3,4,5th gears and new synchros if they are getting old.
or buying a used USDM ITR tranny complete
install a good clutch like exedy stage 1 upgrade, you dont need an over sprung clutch package unless you have more than 150 at the wheels and most tuned honda cars DONT.
lighter flywheels help and dont buy a clutch disk with spun copper in the material, they eat flywheels. go for something similar to stock with stronger construction, possibly kevlar clutch.
once this thing is tuned on the dyno properly, I would expect to see 165/123 on SAE corrected spinning 8400 on stock cams. that is considered strong for stock
00-01 ITR range.
once you have this, work on your suspension, or do your suspension first on stock motor who cares about straight line only acceleration anyways. if you dont have traction it will be wasted wheelspin. find a good breakpad and tire combination that works for you and be happy. an ITR can be modded to... keep this in mind. focus more on making your car as nimble as it can be for what it is. Learn what your wear items will be for your type of driving and plan accordingly.
Thats all I have to say about that. GSRs can be made to compete with Rs, it only takes time and effort and smart modding so you dont go broke in the process.
DC2R_GUY
Dec 23, 2013 05:24 AM
VTEC_PRODUCTION
10
Jan 11, 2008 08:33 PM
Al-sonic
Feb 21, 2007 11:50 AM
SleepnCiViC
Feb 4, 2004 07:40 AM
texasSI
Sep 4, 2002 10:49 AM
