Which pliers type ring compressor to get?
Old Jan 2, 2011 | 06:53 PM
s1ngle's Avatar
Default Which pliers type ring compressor to get?
I got an "Alltrade" (When I got it the box said powerbuilt?) piston ring compressor set. It has some raised bumps inside the band (where the hooks for the handle were attached I believe) and it turns out those bumps actually scored the piston.
When I look at pictures on amazon and other places, they all seem exactly the same. Who sells a decent set of pliers-type piston ring compressors that won't mar my pistons when I use them?
I'm thinking about maybe trying the typical 2-band ring compressor next. The pliers type just seemed tricky to use/hard to hold the same pressure on the tool while pushing the piston in. Ideally I'd have a full array of the ARP tapered compressors, but that isn't feasible for me right now, so I just want a more universal set.
Thanks!
Old Jan 3, 2011 | 06:17 AM
fcm's Avatar
fcm
Old Fart
Default Re: Which pliers type ring compressor to get?
This is the one I have... http://www.wonderbart.com/2009/04/ne...c-clip-pliers/ 94
Old Jan 3, 2011 | 06:45 AM
Chiovnidca's Avatar
I think this is the one i have. It was years ago and repackaged by matco.
http://www.thetoolwarehouse.net/p-26...tools-850.aspx
Old Jan 3, 2011 | 06:46 AM
s1ngle's Avatar
fcm - yeah, thats a 2 band. Just wondering what brand of scissor/pliers type ring compressors people have.
Chiovnidca - Those look exactly like the ones i have. I'm a bit wary about buying another set of what might be exactly what i already have.
Old Jan 3, 2011 | 07:55 AM
h2.4's Avatar
I use the snap on scissor style ring compressor. I haven't had any problems scoring the piston. maybe you just have to use the tool a little more, make sure when you get to the ring section of the piston, that your compressor is sitting flat and square on the block or you might be catching rings on the way down. They should lightly to moderately "tap" in, depending on how much chamfer you have on the block. But you shouldn't be "striking" them in. Hope this helps.
Old Jan 3, 2011 | 09:48 AM
s1ngle's Avatar
This is the best picture I could get of the problem. in the innermost band, you can see the raised bumps. They scraped against the piston so much it actually rubbed the black paint off the tool.
http://img33.imageshack.us/img33/895...essorbumps.jpg
Freemananana
Engine Machining & Assembly
26
Oct 15, 2015 09:13 AM
shawn69
Honda Motorcycles
Aug 5, 2009 08:38 AM
8VEYBEYB
18
Jul 20, 2009 07:44 AM
aznboi_2
Apr 26, 2009 09:36 PM
kingofnothing
Jan 29, 2009 03:05 PM
