piston ring compressor wont tighten up?why?
Old Apr 25, 2009 | 12:14 PM
aznboi_2's Avatar
Default piston ring compressor wont tighten up?why?
ok im putting in my pistons right now and when i put i compress it with the piston ring compressor it wont compress all the way. i tried holding it moving up and down to level it and it still wont tighten up the rings so it wont even go down the sleeves.
Old Apr 25, 2009 | 12:16 PM
stevenDAtegra's Avatar
Default Re: piston ring compressor wont tighten up?why?
Is it the compressor that you turn a **** or allen wrecnh to tighten?
Old Apr 25, 2009 | 12:23 PM
aznboi_2's Avatar
allen wrench
Old Apr 25, 2009 | 12:43 PM
mar778c's Avatar
Community Builder
Community Influencer
This may not help you right now but it is way better to use the sleeves. I f'up a set of oil control rings messing with that collapsible compressor.
I have the wiseco sleeves.
Old Apr 25, 2009 | 03:19 PM
NJIN BUILDR's Avatar
Make sure the oil ring isn't overlapped!!! Some ring compressors will make a funnel shape when tightened.This may be why it looks likes its not tight.You may also be out of its range.
Old Apr 26, 2009 | 09:33 PM
Transpoquick's Avatar
Sleeve compressors are the best but pricey and hard to find, this type is cheap easy to find at any AP store. The edge goes into the bore a little like a sleeve type compressor to keep the rings from hanging up, it also makes it perfectly square with the bore. The pistons go in very easily for me every time I use this thing.
Old Apr 26, 2009 | 09:36 PM
This Type of ring compressor works great and is cheap.
Freemananana
Engine Machining & Assembly
26
Oct 15, 2015 09:13 AM
dem0nk1d
Nov 12, 2012 12:43 PM
Fezzie
Oct 4, 2006 04:35 PM
drunknbass
Jun 3, 2005 01:22 PM
P1mpSlap
Jul 22, 2003 03:57 PM
