Please Read Tranny Question
Old Nov 20, 2002 | 08:09 AM
Reddog's Avatar
Default Please Read Tranny Question
I just had my new diff put in. The tranny guy said that I had 66 nad 15 teeth. Is that a 4.40 final drive and what is the other gearing, help is it a ls or gsr?
Old Nov 20, 2002 | 08:32 AM
CHEETAH's Avatar
Default Re: Please Read Tranny Question (Reddogallmtrcrx)
66/15 = 4.4 final drive ... can be a gsr/type R or b16a
greg
Old Nov 20, 2002 | 11:59 PM
Reddog's Avatar
Default Re: Please Read Tranny Question (CHEETAH)
ok ran into some problems tonight. If it helps any it is a YS1. I was trying to get my tranny on tonight and I couldn't get it to go on. I counted the teeth 24, but when I looked closer the teeth didn't look the same. So I took out the clutch and tried to put it on the tranny, nope didn't go on. OK the flywheel is a LS for sure ( so is the block, the clutch and pressure plate are now unkown, I did notice that the presure plate had a p72 stamped on it. What clutch do I need Help!!! Plus I need to know exatcly what tranny I have hopefully the YS1 will help,
Ryan
Thanks for the help Cheetah
Old Nov 21, 2002 | 05:48 AM
CHEETAH's Avatar
all flywheel and pressure plates are interchangeable for b-series, the dis is th eonly diferrence. The 88-91 spline is smaller than the 92+ spline, if you have the YS1 then you need the 92+ spline which is also the same disc used for 94+ GSR and Type Rs in the hydraulic trannies.
greg
K7-1Ktrevor
Jun 8, 2010 11:30 PM
odogg726
Apr 30, 2007 09:10 PM
6shootahorsenamedtrigga
Aug 8, 2004 11:17 AM
incognitoracerr
Feb 15, 2004 09:42 AM
turbospool
Apr 12, 2003 09:55 PM
