PLEASE HELP NO POWER TO THE ENGINE AT ALL!!
Old Apr 2, 2006 | 03:18 PM
TarProductions's Avatar
Default PLEASE HELP NO POWER TO THE ENGINE AT ALL!!
Ok i am reposting this for a friend who has a spec v we ran into some problems. Any ideas would be greatly apreciated.
Well I pulled the engine to paint the engine compartment and when putting back in installed an ssr turbo kit with an safc2. Long story short made sure everthing was buttoned up all fluids were good, put the battery in and everything, even the safc was keying hot and powering properly. When I tried to crank it sounded like there was not enough power to turn it over so i hooked up a jumper box to give it that xtra kick and boom everthing is dead as in absolutly no power not even the door dinger. Checked all under hood fuses and relays and under dash fuses, and they are all good. power is going to and thru the fuse box and to starter. im stumped ! Any help or suggestions would be great. Thanx.
Old Apr 2, 2006 | 07:02 PM
Runnerdown's Avatar
Default Re: PLEASE HELP NO POWER TO THE ENGINE AT ALL!! (TarProductions)
the main ground wire on the front of the transmission case. is it bolted on.
dc2nerz
19
Apr 21, 2012 06:57 PM
sony224422
May 29, 2006 07:30 PM
TarProductions
Apr 3, 2006 01:40 PM
TarProductions
Apr 2, 2006 08:30 PM
cam003
Audio / Security / Video
Jun 9, 2005 05:27 AM
