Please help me, I'm about to cry............
Old Dec 26, 2003 | 03:39 PM
youngkow's Avatar
Default Please help me, I'm about to cry............
I just changed my head gasket because the other one blew. When I replaced it, I checked the head for warpage, and it was straight and I used a stock honda head gasket with the copper spray. I torqued the arp head studs to 70lbs and started the car, and it is still smoking.
Can I just retorque the headstuds or will I need to replace the headgasket?
_______
Modified by youngkow at 7:09 PM 12/26/2003
Old Dec 26, 2003 | 04:53 PM
doublejz's Avatar
Default Re: Please help me, I'm about to cry............ (youngkow)
just retorque them to the specs. if that doesn't work maybe your head wasn't straight (possible worst case, your cracked your block due to lack of coolant when your blew your head gasket) Just retorque them, good luck
Old Dec 26, 2003 | 05:14 PM
ProdriveWRC's Avatar
Default Re: Please help me, I'm about to cry............ (doublejz)
Are you sure your block wasn't cracked? I've seen a problem before where the cylinder wall was cracked but the owner thought it was a head gasket due to blowing white smoke. When he changed gaskets, the piston was near TDC so he didn't see the crack in the cyl wall. He buttoned the engine back up and when he started it, it was still blowing white smoke. Good luck.
Alin
Old Dec 26, 2003 | 05:28 PM
ZaksZCrex's Avatar
Default Re: Please help me, I'm about to cry............ (ProdriveWRC)
if its craked just put some duck tape on it it will be fine jp yeah what kind of motor do u have in it ??
Old Dec 26, 2003 | 06:38 PM
99blackcivicSi's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by youngkow &raquo;</TD></TR><TR><TD CLASS="quote">I just changed my head gasket because the other one blew. When I replaced it, I checked the head for warpage, and it was straight and I used a stock honda head gasket with the copper spray. I torqued the arp head studs to 70lbs and started the car, and it is still smoking.
_______
Modified by youngkow at 7:09 PM 12/26/2003</TD></TR></TABLE>
Did you do a stage torque on them like 23-70 then back out and repeat 2 more times like is recomened it is possible that you have an inconsitant torque on the head and it could be leaking. Lets hope that that is all it is.
Old Dec 26, 2003 | 08:40 PM
youngkow's Avatar
Default Re: Please help me, I'm about to cry............ (99blackcivicSi)
When I took the head off, I spun the crank to make sure none of my sleeves were cracked. I don't know what to do. If I knew any competent shops, I would take it to them, but I hear bad things about shop in chicago. I think I might get out.....
flozella
Aug 30, 2014 07:20 PM
JDMpadawan
Mar 18, 2014 12:27 PM
strike1545
May 24, 2010 10:42 AM
simpletuning
Classic Hondas
11
Oct 8, 2009 03:53 PM
hawaii_boi_808
Jun 20, 2008 09:17 PM
