please help!!! itr swap
Old Aug 6, 2005 | 07:43 PM
krskrypto23's Avatar
Default please help!!! itr swap
aiighte, so i have a 99 hatch and put a 00 usdm b18c5 itr in... i wanted to use a p73 ecu for the engine... so i bought one that is obd2a ... bought a conversion harness from obd2b->obd2a because i am using a 00 si wire harness.... anyhow, i tried driving it around and it seemed fine... except for a CEL.. (haven't gotten time to check code yet) ... but when i rev to 4000 rpm, it goes nuts and revs up higher and higher until it reaches 7000-8000 rpm.... and then goes back down after a few seconds... wat's going on? any ideas? help!!! thanks
Old Aug 7, 2005 | 03:50 AM
Default Re: please help!!! itr swap (krskrypto23)
bump.
Old Aug 7, 2005 | 02:01 PM
bump... i know someone knows
Old Aug 7, 2005 | 02:27 PM
found out the codes.. now what the hell do i do?
CEL 41 Front Heated O2 Sensor Heater Circuit Fault (Sensor 1)
CEL 20 Electrical Load Detector Circuit Low Input
Old Aug 7, 2005 | 06:24 PM
someone??
Old Aug 8, 2005 | 08:10 AM
bump
MarkCayabyab
10
Dec 25, 2012 05:37 AM
ChangT
Oct 22, 2009 10:49 AM
djickabod
Jul 4, 2004 07:15 AM
