Please help inside!! What in the world is this thing??!!?
Old Apr 19, 2003 | 10:25 PM
B00ST2nR's Avatar
Default Please help inside!! What in the world is this thing??!!?
Ok. I have a breather filter on my valve cover, instead of the tube from the AEM Intake nipple.
I heard its illegal and not good for the car, so I wanted to take off the breather filter.
Anyways, I didn't do the Skunk2 IM install. A friend of mine did it, and it seems he connected the Intake nipple hose to some weird device that I don't know of.
What is that thing? Will something bad happen if I take the hose off and put it on the Breather?
What is that hose connected to and what purpose does it serve?
How am I suppose to take the Breather filter off and replace it with the Intake nipple hose when its connected to that weird thing?
Someone help me out. Thanks.
Old Apr 19, 2003 | 10:28 PM
Starrman85's Avatar
Default Re: Please help inside!! What in the world is this thing??!!? (Skunk2nR)
good question. that is wierd. no clue what that is hooked up to.
Old Apr 19, 2003 | 10:36 PM
SCsol's Avatar
Default Re: Please help inside!! What in the world is this thing??!!? (STARRMAN85)
i think is a evap perge valve!! keep it
Old Apr 19, 2003 | 10:45 PM
B00ST2nR's Avatar
Default Re: Please help inside!! What in the world is this thing??!!? (SCsol)
Umm.... ok.
Then what was that originally connected to? and where is it now?
If I connect the Intake nipple hose to the Breather, like its suppose to be... then that weird device thing will have an empty hole in it, since the hose isn't connected to it anymore...
So then what is suppose to connect to that? Or do I just leave it open like that? Someone help me out.
Old Apr 19, 2003 | 10:47 PM
Starrman85's Avatar
not to be an ***, but how about you ask your friend who installed it, what it was orignially connected to. just a thought.
Old Apr 19, 2003 | 10:52 PM
B00ST2nR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by STARRMAN85 &raquo;</TD></TR><TR><TD CLASS="quote">not to be an ***, but how about you ask your friend who installed it, what it was orignially connected to. just a thought. </TD></TR></TABLE>
He lives an hour away from me, and is always at work. I emailed him this thread, so if he does come online, he'll be responding here...
But anyone else?
Old Apr 19, 2003 | 10:54 PM
Starrman85's Avatar
ok.
i kno on some intakes, there are two outlets/nipples, whatever you like to call them. i kno on my intake, i just have a outlet/inlet for the breather hose, but i have a 92 accord. the breather tube might connect to where that connector is right now, and that connector might hook up somewhere else?
Old Apr 19, 2003 | 11:14 PM
94cxhybrid-T's Avatar
New User
it needs to go to a vacuum source. it is origionally connected to a nippple just off to the side of the throttle body on the stock Intake manifold. you can put a t-fitting on the vaccum hose that goes to the pcv valve and connect that hose to it. The other end of the hose shouild be going from that Evap solenoid to the Charcoal canister on the firwall. HTH
Old Apr 20, 2003 | 09:00 AM
Mr.Saturn's Avatar
Default Re: Please help inside!! What in the world is this thing??!!? (94cxhybrid-T)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94cxhybrid-T &raquo;</TD></TR><TR><TD CLASS="quote">it needs to go to a vacuum source. it is origionally connected to a nippple just off to the side of the throttle body on the stock Intake manifold. you can put a t-fitting on the vaccum hose that goes to the pcv valve and connect that hose to it. The other end of the hose shouild be going from that Evap solenoid to the Charcoal canister on the firwall. HTH</TD></TR></TABLE>
what he said
Old Apr 20, 2003 | 11:55 AM
B00ST2nR's Avatar
Default Re: Please help inside!! What in the world is this thing??!!? (Mr.Saturn)
Wait... so can I just take that hose off and put it on the breather? And leave that opening, open?
Will it mess anything up? What is SUPPOSE to be hooked up to that device, if not the intake nipple hose??
Old Apr 21, 2003 | 10:12 AM
POWERLINE125nosLSVTEC's Avatar
wuddup jun! dang my bad for not getting back to you so fast, but that thing is your ambient iat( intake air tempurature sensor), theres 2 on obd2's for your year gsr. the reason why its hooked up there is because that skunk2 im doesnt have an extra nipple for it, i can see why, one reads ambient air temp and the other reads manifold air temp, i hooked it up that ways to prevent you from getting a trouble code. obviously it will work perfect for obd1 gsr's. if you want to remove the breather we have to put another nipple on the intake arm (i dont know if that is legal either). we just have to hook up and play with it. im pretty sure we can figure something out.
Modified by POWERLINE125nosLSVTEC at 12:17 PM 4/21/2003
Old Apr 21, 2003 | 10:25 AM
New User
Default Re: Please help inside!! What in the world is this thing??!!? (POWERLINE125nosLSVTEC)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by POWERLINE125nosLSVTEC &raquo;</TD></TR><TR><TD CLASS="quote">wuddup jun! dang my bad for not getting back to you so fast, but that thing is your iat( intake air tempurature sensor) the reason why its hooked up there is because that skunk2 im doesnt have an extra nipple for it, with out it you will just get an annoying cel code. you might want to check with them to see if their manifolds differ for year to year, obviously it will work perfect for obd1 gsr's. if you want to remove the breather we have to find another vacuum source to T off with. (i dont know if that is legal either) so you can run a hose to the intake nipple.</TD></TR></TABLE>
sorry that is not the iat. the iat is already on his intake manifold on the right side in the first pic. I already answered his question. One hose goes to the evap canister and the other goes to vacuum source.
Old Apr 21, 2003 | 10:32 AM
Black 2K's Avatar
IAT is on the manny..... That is a ITR AEM? ITR intakes dont have the IATs on the inlet pipe, they are wired for where it looks like you have it, on a primary on the manny.
99-00 as far as i know is the ony car with the IAT on the inlet pipe.... the rest should all be on the manny. Just t off another vaccum and you will be success
Old Apr 21, 2003 | 11:34 AM
Default Re: Please help inside!! What in the world is this thing??!!? (Black 2K)
ill stand corrected. right on every body for your input, well jun just hit me up. peace out
Old Apr 21, 2003 | 12:00 PM
B00ST2nR's Avatar
Ok.
So I'll get me a hose and connect the intake arm to the Breather, and I'll get a T-fitting on the Vacuum hose that goes to the PCV Valve.
That should fix everything, correct?
Old Apr 21, 2003 | 03:25 PM
B00ST2nR's Avatar
Ok. After looking into this problem, I found out that I needed to connect that hose into a vacuum source. That hose was originally plugged into the STOCK Intake Manifold, but the Skunk2 IM didn't have it. I needed a T-Fitting on the Vacuum hoses that connected to the PCV Hose and the hose that went on top of the Skunk2 Intake Manifold.
I went to Kragen Auto Parts, and bought me 3 feet of hoses, Hose Clamps, and the T-Fitting. Spent $20 bucks on all that.
Came back home and popped my hood and checked everything out.
WHHHHAAAAT?! The PCV Tube (Red Thing), was disconnected the WHOLE time!! Even during my Dyno tuning. It was just dangling... (If the PCV Hoses are disconnected, will it affect any performance?)
Anyways, I unplugged all the hoses, uncluding the one that was on the Evap Purge Valve.
First, I removed the Breather Filter and connected a hose to the intake arm to the breather.
Then I got the T-Fitting and connected the Evap hose, PCV Hose, and the vacuum hose together. Clamped each hose off tightly.
Then connected the Evap hose to the Evap Purge Valve (That weird device we were talking about).
I reset the ECU then let her run for a good 5-10 minutes.
It runs great now. Thanks for everone's help!
Duc_du
Jul 19, 2010 12:36 AM
young geezer
Aug 3, 2009 02:34 AM
youradhere
Oct 9, 2006 09:25 PM
CIVICNONVTEC
Jul 21, 2003 06:41 PM
B00ST2nR
Apr 21, 2003 03:23 PM
