HELP!!!!!!!!!! trying to pull tranny out tonite
i'm trying to pull my auto tranny out of my coupe i almost certain i have all the bolts out i left the starter on because it's on the one i'm replacing it with. all mount holding it on are off. it would seprate from engine help please asap.
Re: HELP!!!!!!!!!! trying to pull tranny out tonite (RedSix)
no how do i get to them? isn't the torque converter sandwish between the motor and tranny newbie question?
Re: HELP!!!!!!!!!! trying to pull tranny out tonite (JJ's civic)
help anyone it's late and i want this thing out!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
took starter out still won't move away i need help need this car to run tomorrow
it's been awhile but i'm pretty sure u have to unbolt the torque converter from the flexplate... there should be and little opening right where the oil pan and the transmission meets...us an 19mm socket to turn the crank...you should see the bolts that you have to take off...good luck
Re: HELP!!!!!!!!!! trying to pull tranny out tonite (hard_boiled_EG)
i think that is the isue thanks i'm trying that as i type(my buddy is under the car now.
took bolt from convorter from flex plate still wont come apart HELP!!!!!!!!!!!!!!!!!!
i gave up for tonite. i can't figure it out. any suggestion will be great i need this out by noon tomorrow(my buddy leaves for ct.
UPDATE!!!!
i got the tranny out i used a framing hammer and a 2x2 piece of wood to sprate a little then use a screwdriver to sprate move then i used my blaa joint puller forky thing to seprate urther more then i just gave it a tug on the other side to free the other pin and she drop right out.( i just had to lift the car a little more to drag the frucking thing out [it's really [freak]ing heavy])
Xemu
10-03-2006 10:16 AM
