help electrical problem!!
Old Oct 3, 2010 | 11:54 AM
karrar55's Avatar
Default help electrical problem!!
just bought a 94 honda accord ex vtec!! but the problem is that the horn, door lock switch, overhead light and dashboard lights does not work. everything else works like the windows cigerette lighter ect. ect.
help would be very appreciated!!! thanks!
Old Oct 3, 2010 | 01:07 PM
redbull-1's Avatar
Default Re: help electrical problem!!
Have you checked the fuses first? Check the under-hood fuse box.
For the under-hood fuse, no. 30 fuse (20A) for the horn, no. 32 (15A) for the dash lights, etc., no. 32 (20A) for the power locks, no. 37 (7.5A) for ceiling light, etc.
Old Oct 3, 2010 | 01:36 PM
karrar55's Avatar
ya i checked the fuses and they are all good even the ones inside the car.
Old Oct 4, 2010 | 03:53 PM
poorman212's Avatar
Does this have an alarm system installed.....redbull-1 knows the answers. I'm just trying to get more details.
Old Oct 4, 2010 | 04:15 PM
DELuth's Avatar
Troubleshoot each system individually. I'm betting you have 4 seperate problems.
Old Oct 4, 2010 | 06:54 PM
karrar55's Avatar
U guys think not having a radio will effect it??? Cause online people started having electrical problems when they removed the radio
Old Oct 4, 2010 | 07:00 PM
redbull-1's Avatar
Generally, no. You might have electrical problems if the wires were cut and not properly insulated which may cause a short; for example, if a positive (+) bare wire touch metal or ground.
The best advice is DEluth' advice to troubleshoot each system separately. For example, using a multimeter, test light, etc. and following troubleshooting steps from a service manual.
velocity66
Aug 4, 2011 03:17 PM
Paopalo
Aug 2, 2011 08:43 PM
infecto
Jun 20, 2006 07:27 AM
