please help
Old Jul 15, 2008 | 07:10 PM
adam00's Avatar
Default please help
i have a jdm f22b Dohc and today i took off the spark plug and on the 4th sparkplug it was all dirty on the tube that goes down to the spark plug so i took off the valve cover and replaced that little gasket and i see that some off the oil on top was white (when i drained the oil it was brown) do you think that could be anti freeze mixed with the oil then i was looking and i seen that there was a little rust on the top of the cam lobe for the 4th cylinder is this good or bad and should i take the cams out of the h23 they have no rust and put them in there??
also on my f22b there are 8 loose bolt under the valve cover i think the adjust the valves they have a flat head on top and have a nut on it how do i adjust them and when i looked on my h23 there was like 12 loose ones
Old Jul 16, 2008 | 07:51 AM
adam00's Avatar
Default Re: please help (adam00)
anyone know
ducsaim
Apr 15, 2020 09:10 PM
Bonezekhatch
Engine Machining & Assembly
Jan 12, 2016 09:48 PM
honda_sol_vtec
Mar 12, 2009 09:47 AM
quazar
Jun 22, 2004 06:46 PM
screech
Jul 13, 2003 12:44 PM
