Plasticgauge the wrong way?? HELP
Old May 24, 2006 | 02:24 PM
MRturbo's Avatar
Default Plasticgauge the wrong way?? HELP
alright i am all ready to redo my plasticgauge but which way is the correct reading? Do i do it like how i marked it in GREEN ? or is doing it in RED the correct way?? and if i do it the RED way, will it throw off my reading??
well i did it the red way and all my readings came to .001, all mains and rod bearings.
Old May 24, 2006 | 03:54 PM
johnnylawless's Avatar
Default Re: Plasticgauge the wrong way?? HELP (MRturbo)
use the green, and lay it as straight as possible across the bearing surface
Old May 24, 2006 | 04:12 PM
MRturbo's Avatar
Default Re: Plasticgauge the wrong way?? HELP (johnnylawless)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by johnnylawless &raquo;</TD></TR><TR><TD CLASS="quote">use the green, and lay it as straight as possible across the bearing surface</TD></TR></TABLE>
will doing it the red way will screw up the readings?
Old May 24, 2006 | 05:56 PM
Combustion Contraption's Avatar
yes
Old May 25, 2006 | 08:41 AM
NITROUSHONDA's Avatar
green is correct
j0hn-0h
Jan 11, 2007 11:02 AM
NA JDM GSR
Oct 16, 2006 03:01 PM
modulo_s
Honda Motorcycles
47
Apr 12, 2005 03:23 PM
ImpoRTride
15
May 23, 2003 06:34 PM
