what rings?
Old Nov 23, 2006 | 01:57 PM
CivicVX94's Avatar
Default what rings?
i'm building a motor to get me through the winter.
i'll be using my current turbo set up and not looking for any extreme numbers (275ish whp on a md).
the motor is a b18a1 w/ b16 pistons and a pnp/deshrouded valves/polished combustion chambers ls head. i figure i should be able to pick up a few ponies with the new setup over my stock ls turbo.
so my question is, what piston rings should i run? and what should i gap them to?
keep in mind, this is my daily driver and i'm not looking for any extreme numbers, just something stout and reliable for boosted stock engine.
Thanks in advance for any input
Old Nov 23, 2006 | 02:05 PM
BoostedEG6's Avatar
Default Re: what rings? (CivicVX94)
if your running oem pistons then run oem rings.....
Old Nov 23, 2006 | 04:03 PM
platinum00's Avatar
Always use the rings the came with the pistons and the recommended gap.
platinum.
Old Nov 23, 2006 | 05:59 PM
CivicVX94's Avatar
Default Re: what rings? (BoostedEG6)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BoostedEG6 &raquo;</TD></TR><TR><TD CLASS="quote">if your running oem pistons then run oem rings.....</TD></TR></TABLE>
cool...what gap would you recommend? if you have any idea
b20beast83
Apr 22, 2010 09:32 AM
Clerique
Oct 4, 2008 05:14 PM
W C L
Oct 17, 2005 01:51 PM
quik1
Jun 19, 2004 06:33 PM
quik1
Jun 9, 2004 07:48 PM
