pistons
Old Mar 15, 2005 | 07:33 AM
dizzyroc88's Avatar
Default pistons
does anyone offer oversized stock pistons for h22/23. if so what sizes and where.
thanks in advance
Old Mar 15, 2005 | 07:44 AM
NJIN BUILDR's Avatar
Default Re: pistons (dizzyroc88)
http://www.hondaautomotiveparts.com/ They list a .25mm oversize.Make sure the shop knows how to bore/hone the composite cylinder walls.I would bring it to a Honda specialist.
Glenn
Old Mar 15, 2005 | 07:46 AM
dizzyroc88's Avatar
Default Re: pistons (NJIN BUILDR)
i will not have to sleeve the block to be able to run these pistons right?
Old Mar 15, 2005 | 07:52 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dizzyroc88 &raquo;</TD></TR><TR><TD CLASS="quote">i will not have to sleeve the block to be able to run these pistons right?</TD></TR></TABLE>
Correct.No sleeving required.These are Honda oem oversize replacements.I believe the machine shop will needs a special honing stone set to finish the cylinder walls.
Glenn
Old Mar 15, 2005 | 01:25 PM
dizzyroc88's Avatar
i can use these on stock rods? thanks for the info by the way...i had to order them this morning
Old Mar 15, 2005 | 05:57 PM
PrettyLude's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dizzyroc88 &raquo;</TD></TR><TR><TD CLASS="quote">i can use these on stock rods? thanks for the info by the way...i had to order them this morning</TD></TR></TABLE>
yes
Lude-acris
Apr 7, 2005 03:29 AM
GWInquisitor14
Jun 16, 2004 06:45 PM
crxrich_kid
Feb 21, 2004 01:25 PM
hotintegranights
May 13, 2003 11:50 AM
InsertCleverSN
Apr 27, 2003 06:41 PM
