Piston Speed Graph
Old Mar 20, 2005 | 12:40 PM
Combustion Contraption's Avatar
Default Piston Speed Graph
With all the discussion lately surrounding piston speed, and rod to stroke ratio i decided to make a little excel graph displaying the difference in piston speed relative to RPM between an 89mm (LS) stroke and a 77mm (b16) stroke. You can see just one of the reasons clearly why b16's dont mind 9000 rpm.
LS is blue
B16 is pink
Old Mar 20, 2005 | 04:27 PM
No techies are interested in this? surprising....
Old Mar 20, 2005 | 05:53 PM
drdisco69's Avatar
Default Re: (LsVtec92Hatch)
So the piston speed of the LS isn't completely linear?
I can't speak for anyone else, but this isn't exactly suprising, it's what must happen by the definition of the geometry of the motors. Good info though, many people don't understand what really goes on in a motor.
Old Mar 20, 2005 | 07:49 PM
Default Re: (drdisco69)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by drdisco69 &raquo;</TD></TR><TR><TD CLASS="quote">So the piston speed of the LS isn't completely linear?
if youre referring to that little "hump" in the ls graph, i dont know why its there.... i went back and double checked it and all my math was correct. So for now, im gonna blame it on excel.
Old Mar 20, 2005 | 09:32 PM
Greenery18's Avatar
So what are the units of measurement then? MPH?
also, at what point in the stroke are you measuring the speed? near TDC the piston speed is slow, so i'm guessing you are gauging it at 90 degrees...?
Nameless RB26's Avatar
Very cool.
You should do this with a stock LS/VTEC.
Old Mar 21, 2005 | 06:35 AM
EE_Chris's Avatar
Default Re: (Nameless RB26)
Not to steal your thread, but have a peep at this:
Engineer's Edge - Engine Formula's
Old Mar 21, 2005 | 11:32 AM
Default Re: (Greenery18)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Greenery18 &raquo;</TD></TR><TR><TD CLASS="quote">So what are the units of measurement then? MPH?
also, at what point in the stroke are you measuring the speed? near TDC the piston speed is slow, so i'm guessing you are gauging it at 90 degrees...?</TD></TR></TABLE>
Its in FPM (feet per minute). The formula i used is for mean, or average piston speed. The speed of the piston changes with practically every degree of crankshaft rotation, so a graph of that, to me at least, is impractical.
Old Mar 21, 2005 | 01:43 PM
drdisco69's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LsVtec92Hatch &raquo;</TD></TR><TR><TD CLASS="quote">The speed of the piston changes with practically every degree of crankshaft rotation, so a graph of that, to me at least, is impractical.</TD></TR></TABLE>
But you can find the maximum velocity, and the acceleration, which are practial, to a certain extent. I have the math somewhere, I'll have to find it.
Old Mar 21, 2005 | 02:07 PM
notstock93's Avatar
You may want to label the graph for everyone else out there.
Good info, though.
But you can find the maximum velocity, and the acceleration, which are practial, to a certain extent. I have the math somewhere, I'll have to find it.</TD></TR></TABLE>
I dont have time to graph it right now but max velocity for an LS stroke (89mm)at 8000rpm is 202.25mph while the max acceleration is 4.780mph.
B16 (77mm stroke)'s max velocity is 167.44mph while the max acceleration is 3.633mph.
Old Mar 21, 2005 | 02:24 PM
Burke's Avatar
Banned
mph isnt a measure of accel. is it mph/h or mph/s??
Old Mar 21, 2005 | 02:28 PM
drdisco69's Avatar
Check your units on acceleration, should be time squared.
Old Mar 21, 2005 | 02:58 PM
I will check nothing!!!!!
j/k, im @ work right now, ill check it later...
Old Mar 21, 2005 | 06:46 PM
carnifex's Avatar
i used to drag race a pontiac firebird with a cadillac 500. my buddy and engine builder said he wanted to get 6k rps out of it. no dice that damn engine has an almost 110mm stroke. i got a calculation on it done and i was running the same piston speed at 5k rps as a 5.0 ford at 8125 rpms. we glazed a few cylinder walls in our time but sure had some fun.
Old Mar 21, 2005 | 08:12 PM
6k rpm out of a 110mm (4.323") isnt too bad. At 6000rpm your mean piston speed (4323fpm, same number as your stroke ironically enough) is still better than an LS (89mm) at 8000rpm. (4666fpm).
Old Mar 21, 2005 | 08:59 PM
Greenery18's Avatar
B16 (77mm stroke)'s max velocity is 167.44mph while the max acceleration is 3.633mph.</TD></TR></TABLE>
How could this be true? A higher revving(shorter stroked) engine should have FAR higher acceleration speeds after TDC... as well as having an overall higher velocity.
Old Mar 22, 2005 | 11:18 AM
How could this be true? A higher revving(shorter stroked) engine should have FAR higher acceleration speeds after TDC... as well as having an overall higher velocity.</TD></TR></TABLE>
That depends more on rod length than stroke. A shorter rod engine will have faster acceleration from TDC. (Or one with a lower r/s ratio if thats how you prefer to look at it.)
Old Mar 22, 2005 | 03:44 PM
carnifex's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LsVtec92Hatch &raquo;</TD></TR><TR><TD CLASS="quote">6k rpm out of a 110mm (4.323") isnt too bad. At 6000rpm your mean piston speed (4323fpm, same number as your stroke ironically enough) is still better than an LS (89mm) at 8000rpm. (4666fpm).</TD></TR></TABLE>
5k rpm with a gm crank on 110 mm is awesome. i threw out a few of them. i know.
Old Mar 22, 2005 | 04:33 PM
Maybe GM has low quality cranks, im not aware of that, sorry....
Old Mar 22, 2005 | 05:00 PM
Lu DC2's Avatar
Default Re: Piston Speed Graph (LsVtec92Hatch)
I like it!
95lstegman
Nov 24, 2005 07:27 PM
ModenaTwinTurbo
May 18, 2005 01:45 PM
91integraLSVTEC
Feb 15, 2004 03:53 PM
Elex
Feb 27, 2002 11:14 AM
HXMan
Sep 19, 2001 06:48 AM
