piston and rods question please help!
Old Mar 20, 2008 | 12:12 PM
integra gsr96's Avatar
Default piston and rods question please help!
i was wondering if i get eagle rods and a different type of pistons would it affect anything power wise?
Old Mar 20, 2008 | 01:55 PM
inspyral's Avatar
If you change the compression ratio then, yes, that will affect power.
Old Mar 20, 2008 | 09:20 PM
civicstar's Avatar
Default Re: piston and rods question please help! (integra gsr96)
higher compression on NA "may" mean more power, rods are more for integrity if you boost or push you motor hard
Old Mar 21, 2008 | 08:53 AM
Default Re: piston and rods question please help! (civicstar)
is 12.1 compression to high for nitrous? or should i go 11.5?
Old Mar 21, 2008 | 01:26 PM
King V's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by integra gsr96 &raquo;</TD></TR><TR><TD CLASS="quote">is 12.1 compression to high for nitrous? or should i go 11.5?</TD></TR></TABLE>
12:1 is quite a bit for any engine especially on pump gas, and if you're going to bottle feed it at that compression, you better have your ignition timing on complete lockdown or you'll have a giant aluminum paperweight, regardless of how much HP it's jetted for or what kind of rods you use.
Old Mar 22, 2008 | 12:05 PM
Default Re: piston and rods question please help! (King V)
what do you mean by ignition on lockdown?
Old Mar 22, 2008 | 04:00 PM
Mikey3000's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by integra gsr96 &raquo;</TD></TR><TR><TD CLASS="quote">what do you mean by ignition on lockdown?</TD></TR></TABLE>
he means dead nuts on.
Leland
Oct 1, 2009 01:33 PM
lsvtechatch92
Jul 18, 2007 01:51 AM
redhondacivic
Jun 10, 2006 01:57 PM
lavo81
May 8, 2005 03:48 PM
