Piston Rings...Just a Question...PLZ HELP!
ok im in the process of replacing the gaskets/seals/rings...etc on my b16A..
now the only choices i have for piston rings apparently is either std or 0.25 over...now i was told if ure replacing the rings u need to go larger? is this correct and if it is how would i go about using 0.25 rings on stock pistons...someone apparently told me i needed to go 10/1000 of an inch?? someone plz help me out
Well it's hard to say. If you're using the same pistons and you aren't altering the bore size, then there would be no reason to get larger rings... I think someone was telling you to get larger pistons, not rings.
But then again, you aren't supposed to rebuild a motor without boring or at least honing it. If you install new rings without honing the cylinder walls, the rings won't seat right.
If that's the case, you'd be better off not messing with the pistons/rings at all.
the motor is at 100,000 miles...so wut should i do? the pistons look fine
i need some input..should i just hone it ? and if i do hone it wut size rings should i get?..sorry man i'm a noob to this..
If the pistons look good (i.e. no excessive side-skirt wear) then what you should do is hone the cylinder walls and install new rings onto the pistons. Don't worry about that oversized-ring garbage, I don't know who told you that.
But definitely hone the walls when you install the new rings. It's important.
Basically, a typical engine rebuild entails a few simple things:
1. Replace main and rod bearings
2. Hone cylinder walls
3. Replace piston rings
4. Replace all seals and gaskets (including valve seals)
Do you have a Haynes manual? If you don't, then go buy one - it goes over basic motor rebuilding in rather good detail.
