Piston question
Old Jun 20, 2003 | 11:51 AM
mark72's Avatar
Default Piston question
Would i be able to install some itr pistons in my Ls motor?
If so, would i have to change anything out?
Old Jun 20, 2003 | 02:54 PM
Rocket's Avatar
Default Re: Piston question (mark72)
You'll need to narrow the small ends of your stock LS rods by 0.060" to make sure you have the proper clearance to install ITR pistons on them.
These are some rods we do that are narrowed at the small end and fitted with ARP rod bolts and the big ends are re-machined for perfect roundness.
Old Jun 20, 2003 | 02:56 PM
godnf8's Avatar
if you do all the work yourself you can have a local machine shop narrow the rods and put the pistons onto the rods for you, should cost that much.
Old Jun 21, 2003 | 01:16 AM
mark72's Avatar
Default Re: Piston question (godnf8)
Cool. So basically, i wouldnt have to change anything else
besides have them narrowed down? Would i feel a big
difference?
Old Jun 21, 2003 | 06:03 PM
ENeRg3Tic's Avatar
do a search im sure you will find more info.
im not positive but i think getting rods machined is only needed for ctr pistons
itr pistons should fit
Old Jun 21, 2003 | 06:33 PM
letholone's Avatar
Default Re: Piston question (Rocket)
rocket,
are those just stock rods that you have modified?
how much do you sell those for?
Old Jun 23, 2003 | 12:48 PM
Rocket's Avatar
Default Re: Piston question (letholone)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by letholone &raquo;</TD></TR><TR><TD CLASS="quote">rocket,
how much do you sell those for?</TD></TR></TABLE>
Yes those are modified and rehoned stock PR4 rods w/ ARP bolts. They are $125 plus core.
Z.E.R.O.
24
Mar 14, 2009 11:15 AM
thehatchninja
Dec 12, 2006 02:25 PM
BoostinEm1
Apr 20, 2006 09:10 AM
CRX MASE
Mar 31, 2006 09:06 PM
lscoupe
May 18, 2005 02:20 PM
