Piston orientation
Old May 15, 2003 | 02:02 PM
senpai's Avatar
Default Piston orientation
I feel dumb as **** ... I have no idea which side of the piston is intake and exhaust. How do you also figure out cylinder number?
Old May 15, 2003 | 03:06 PM
VTEC-DA's Avatar
Default Re: Piston orientation (maztur)
Pistons arent cylinder specific.
Old May 15, 2003 | 03:32 PM
turbo sol's Avatar
Default Re: Piston orientation (VTEC-DA)
intake valves have deeper reliefs than the exhaust valve relief. what pistons are you trying to figure out? the stock pistons usually have an IN stamped on the intake side.. make sure you put them on the rod the right way, there should be an oiling hole in the rod so it does matter how you assembke it.
Old May 25, 2003 | 09:55 AM
senpai's Avatar
Default Re: Piston orientation (turbo sol)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turbo sol &raquo;</TD></TR><TR><TD CLASS="quote">intake valves have deeper reliefs than the exhaust valve relief. what pistons are you trying to figure out? the stock pistons usually have an IN stamped on the intake side.. make sure you put them on the rod the right way, there should be an oiling hole in the rod so it does matter how you assembke it.</TD></TR></TABLE>
So the rod has to be a certain way too? The oiling hole faces which way?
Old May 25, 2003 | 10:26 AM
IN VTEC's Avatar
Oil orifice in the rod faces the intake side, same way as the IN on the piston.
There's also an on the piston that points to the front/pulley side of the engine.
eg:R
Mar 4, 2007 03:35 PM
egvtec
Nov 30, 2004 11:13 AM
senpai
May 15, 2003 03:18 PM
Ltech
Aug 21, 2002 11:12 PM
Xerxes
Feb 22, 2002 12:34 AM
