piston to deck height.
Old Mar 16, 2003 | 12:34 PM
bretx0r's Avatar
Default piston to deck height.
cylinder 4 looks a lot larger of a gap than the rest of the cylinders... can someone tell me what could be wrong.
CYLINDER 1
CYLINDERS 2 & 3
CYLINDER 4
is there somtehing wrong or am i just paranoyed?
Old Mar 16, 2003 | 12:38 PM
matt_sb2000's Avatar
Default Re: piston to deck height. (bretx0r)
Bent a rod maybe? Or spun that bearing.?
Old Mar 16, 2003 | 12:43 PM
Ri5e's Avatar
Default Re: piston to deck height. (matt_sb2000)
so #4 is that low, at TDC?
Pop off the oil pan to find out....
[Modified by 4 Stroke, 1:43 PM 3/16/2003]
Old Mar 16, 2003 | 01:03 PM
IN VTEC's Avatar
Throw a dial indicator on there to confirm TDC....then start making presumptions.
Old Mar 16, 2003 | 01:12 PM
bretx0r's Avatar
Default Re: piston to deck height. (IN VTEC)
i dont need a goddamn meter to tell me when im top dead center thats the point its at just before the piston starts going down it does not go up any more.
and i actually have it backwards
cyl 4 = cyl 1
[Modified by bretx0r, 10:23 PM 3/16/2003]
Old Mar 16, 2003 | 01:18 PM
b18c1_eh2's Avatar
Then you probably don't need goddamn us to tell you what's the goddamn matter with your goddamn motor.
Like it's been mentioned before. Take that **** apart and find out what's wrong. Don't guess.
I always trust stuff like this.
Old Mar 16, 2003 | 01:30 PM
bretx0r's Avatar
Default Re: piston to deck height. (b18c1_eh2)
i took the oil pan and baffle off.....
what should i look for, for signs of anything that might cause this..
Old Mar 16, 2003 | 01:36 PM
BabyDaddy's Avatar
ggggrrrrrr.....
That wa me posting on my boy's s/n cuz his dumbass forgot to lot out.
O.K. Now that you've got the oilpan and windage tray out of the way, grab the rodcap on the cylinder in question and see if it has any play on the crankshaft. If so, then you've got a spun rod bearing. If not, your gonna have to go deeper into the motor to find out. Let me know what happens.
Old Mar 16, 2003 | 01:41 PM
bretx0r's Avatar
Default Re: piston to deck height. (BabyDaddy)
there is no play. the only play is from side to side and that is VERY SMALL amounts of play.. i believe its normal and its the same case on all cylinders
[Modified by bretx0r, 11:11 PM 3/16/2003]
Old Mar 16, 2003 | 01:43 PM
BabyDaddy's Avatar
Alright... stop right there.
Are you comfortable rebuilding engines?
If so dig deeper and find out what's wrong. I'm thinking bent rod but who knows.
If your not comfortable with the internals of the motor then take it to someone who is. Good luck.
[Modified by BabyDaddy, 10:44 PM 3/16/2003]
Old Mar 16, 2003 | 02:12 PM
bretx0r's Avatar
yeah im really not comfterble... im afraid ill **** things up... my friends ASE certified in several fields.. ill prolly have him help...
[Modified by bretx0r, 11:30 PM 3/16/2003]
Old Mar 16, 2003 | 04:09 PM
Chiovnidca's Avatar
Pop that rod and piston out of there and give us a pic.
Old Mar 16, 2003 | 04:38 PM
IN VTEC's Avatar
I do this a lot sometimes....I forget the easiest way to ask a question.
Really I should ask if you took the #1 and #4 picture at the same time, or did you take #1 first, rotate to #2/#3, and then rotate again to take #4?
If you took pictures of #1 and #4 at the same time, then you can rule out not being at TDC as the cause of the taller piston-to-deck height.
Old Mar 16, 2003 | 04:54 PM
bretx0r's Avatar
yep. bent rod.
thank GOD i didnt boost it with the rod like that.
Old Mar 16, 2003 | 05:24 PM
Chiovnidca's Avatar
Yea, boost would probably put it through the side of the block real fast.
Old Mar 16, 2003 | 06:15 PM
smokey2.0's Avatar
Default Re: piston to deck height. (TurboD16Chiovnidca)
good thing you listen to the advice of some wise H-T members, it could have cost you some big bucks!
Old Mar 16, 2003 | 06:21 PM
bretx0r's Avatar
Default Re: piston to deck height. (smokey2.0)
thanks honda-tech
Old Mar 22, 2003 | 09:49 AM
b18c1_eh2's Avatar
damnit i'm not a dumbass, i just forgot to sign off goddamnuit=atgagkhnasdlgk~!!!
Old Mar 22, 2003 | 02:45 PM
Unsung's Avatar
yep. bent rod.
Old Mar 22, 2003 | 04:49 PM
kill bill's Avatar
Default Re: piston to deck height. (JDM B-Series)
seems like more trouble than its worth for a stock SOHC block. you can pick one of those up for nothing or next to nothing.
Old Mar 24, 2003 | 12:18 PM
bretx0r's Avatar
Default Re: piston to deck height. (i need space)
only its my new LS motor not the SOHC
[Modified by bretx0r, 9:19 PM 3/24/2003]
blackeg
Apr 21, 2012 09:59 AM
soulo
Apr 25, 2009 08:58 AM
KEVLARsh
Aug 25, 2007 08:25 PM
freakaccident
Oct 1, 2004 07:45 AM
seako_916
May 19, 2004 09:28 PM
