piston/compression ratio question
Old Jul 6, 2006 | 09:29 PM
JSpin's Avatar
Default piston/compression ratio question
kind of a newb question that i think i know the answer too, but i'm hoping someone might be able to help me out.
i bought these pistons/rods about a year and a half ago, and was told that they were 11:1. i didn't really know what i was doing at the time, and i just jumped on them cause i got a really good deal.
they're actually from the crower b16 stroker kit that uses an 89mm crank; so it's an LS length rod and a shortened piston. anyway, they've been sittin in a box since i bought them and i had planned on putting a motor together here pretty soon and when i pulled them out and i instantly thought there is no way they're an 11:1 piston.
is there a way i can figure out a ballpark range on the kind of compression ration these will have. i've got a caliper and mics, but i dont even know if i can do anything with them in this case. i dont really feel like building the whole motor and then realize great, i have an ultra low compression slow *** motor.
Old Jul 7, 2006 | 11:10 AM
JSpin's Avatar
little help anyone?
Old Jul 7, 2006 | 12:05 PM
unknown0001's Avatar
Default Re: piston/compression ratio question (JSpin)
I'll check out some notes later I have and might be able to find something that will help you exactly calculate what the compression might be.
Old Jul 8, 2006 | 02:30 AM
JSpin's Avatar
Old Jul 8, 2006 | 05:54 PM
non-VTEC's Avatar
those pistons have to much of a "dish" to be 11:1CR.......maybe 9:1?
unless the chambers in the head are really small.
Old Jul 8, 2006 | 09:53 PM
JSpin's Avatar
Default Re: piston/compression ratio question (non-VTEC)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by non-VTEC &raquo;</TD></TR><TR><TD CLASS="quote">those pistons have to much of a "dish" to be 11:1CR.......maybe 9:1?
unless the chambers in the head are really small.</TD></TR></TABLE>
pretty much what i was thinking.......i'd have to hang those things out of the hole like 10feet
JSpin
Jul 16, 2006 11:25 PM
bnut510
Aug 25, 2005 10:54 AM
Akina
Jan 21, 2003 02:07 PM
turboex
Mar 29, 2002 08:38 AM
