piston bearing replacement question
Old Aug 11, 2003 | 03:10 PM
CHK4TIX's Avatar
Default piston bearing replacement question
ok, i have a h22a with I/H/E. while removing the oil pan so i can get a oil return line welded to it. I notice a small amount of metal. The metal is looks the same as on a motor that i spun the bearings on, but near as much. I was wondering if i can just replace the bearings if there is no damage to the crank its self. I want to do this a preventive maintenance so i don't screw up the crank or the block. can this be done?
99siRACER
May 3, 2012 04:41 AM
turboman2.2
Feb 19, 2010 10:55 AM
jbrokos307
13
Oct 21, 2009 05:51 AM
xxmastermindxx
May 6, 2007 09:17 AM
ejcivicdee
Mar 30, 2006 07:38 AM
