building and engine
Old Feb 17, 2010 | 12:42 PM
turboman2.2's Avatar
Default building and engine
how do i replace the crank bearings?
Old Feb 17, 2010 | 12:47 PM
silverwrench's Avatar
Default Re: building and engine
take the old out and put the new in
Old Feb 17, 2010 | 05:32 PM
is that it there is no certain bearings i need, or certain clearance. what size bearing for stock ls crank? and is there a certain way to put them in? how bout the break in for bearings/???
Old Feb 17, 2010 | 05:43 PM
4cylinders-of-fury's Avatar
If your asking this question I don't think you should be replacing bearings. but if you must ,YouTube should have some good videos or pick up a haines manual.
Old Feb 17, 2010 | 05:58 PM
SovXietday's Avatar
Oh dear, this cannot end well.
Old Feb 17, 2010 | 08:09 PM
well would you recomend replacing them i am going for 450 to 500hp ... so what u sayin is i can just put those old ones in?????
Old Feb 17, 2010 | 08:16 PM
im saying take it to a professional
Old Feb 18, 2010 | 03:49 AM
ashb82's Avatar
MAKE SURE YOUR OIL HOLES LINE UP. There is a top bearing and a bottom bearing. If you are a newbie to engine building make sure they line up.
First pic no oil hole in the main Cap
Second pic oil holes in the block to oil the crank
Some good info on building your engine
http://articles.evans-tuning.com/200...-a-gsr-engine/
They even have videos
Old Feb 18, 2010 | 06:19 AM
Silvertc's Avatar
x's 2
Old Feb 18, 2010 | 06:29 AM
tuhboek's Avatar
Evans tuning has alot of good info with step by step video.
Old Feb 18, 2010 | 07:27 AM
Kyle R's Avatar
Yeah. I would suggest that the OP start there.
Old Feb 18, 2010 | 06:24 PM
thanks man.. can i use a gsr girdle on a ls block? i have a girdle lying around would it be better to use the girdle or just the stock ls caps?
Old Feb 18, 2010 | 07:06 PM
ashb82's Avatar
I would use the stock ls caps you cant take caps from one engine and place them on another engine dont work that way. From the Honda factory the caps are machined to match the block. I would not listen to people telling you not to do it yourself. Thats the only way i would do it .If you have never spun a bearing on your crank, order standard size acl bearings then use plastic gauge to size the bearings. Keep posting and asking questions.
Old Feb 19, 2010 | 06:09 AM
hawkturbo's Avatar
Noob ???? sorry for my inglish
wanna put new bearings and y buy acl is just put oh need too use the plastic gauge
y wana put this
http://cgi.ebay.com/ebaymotors/ACL-R...#ht_2968wt_939
thanks for the help
Old Feb 19, 2010 | 08:48 AM
ashb82's Avatar
Those are race bearings they have .001 extra clearance
Old Feb 19, 2010 | 10:55 AM
hawkturbo's Avatar
No idea what you say sorry. What i need to put this bearins
jbrokos307
13
Oct 21, 2009 05:51 AM
xxmastermindxx
May 6, 2007 09:17 AM
racerpat94
Apr 9, 2007 09:41 AM
ejcivicdee
Mar 30, 2006 07:38 AM
precisionelite
Aug 22, 2005 10:37 AM
