pinging/pinking (ITS BAAAACK!)
Ok guys its back again.
Just a little history: Was getting a lot of pinging about a month ago. Timing was last checked back in Nov. of last year and it was spot on 16 degrees. Changed the fuel filter about 3 weeks ago and the ping went away. Las week it started coming back on, so I did an injector cleaning, no difference.
Any ideas now? Worn plugs? bag ign? what else could be the problem.
see signature. also a chipped ecu out of japan. Came with the motor so don't know what program it has on it. No speed cut, no rev limit. Have the car about 2 year with no ping issues. This started about 3 months.
Pull out the plugs and see if it is runnin lean. if so clean injectors, etc..
if not runnin lean, check your timing at idle and try another ecu if you have one around.. do you have a vafc by chance???
civic89si666
10
Feb 26, 2012 05:42 AM
count me out
Oct 9, 2008 08:39 PM
EK_vzla
Sep 16, 2004 08:35 AM
