bluish smoke from start up
Old Apr 28, 2007 | 10:12 AM
b18c-1's Avatar
Default bluish smoke from start up
when i start my car i get a bluish smoke coming from my exhaust for about 10 seconds. then it stops onces i start driving. but it only happens once in a while like maybe 2 to 3 days a week. any ideas what it could be?
Old Apr 28, 2007 | 02:57 PM
inspyral's Avatar
Blue smoke usually means bruning oil. Does your engine consume any oil? How's the mileage on it? Have you done any recent mods prior to it starting to smoke?
Old Apr 29, 2007 | 12:01 PM
b18c-1's Avatar
Default Re: (inspyral)
yeah i knew that it was oil, i havent seen any dramatic changes in oil consumption just the usual from vtec, aslo i have a seeping oil pan gasket that im gunna replace but i dont see why that oil would be coming out of the exhuast. i forgot to mention this is a 2000 gsr. no major mods like the last thing i changed was the oil and plugs
Modified by b18c-1 at 1:35 PM 4/29/2007
Old Apr 29, 2007 | 12:54 PM
charger912's Avatar
Default Re: bluish smoke from start up (b18c-1)
Blue smoke is oil. When you notice it at start up, it typically means that you have oil leaking past your valves.
Old Apr 29, 2007 | 02:33 PM
b18c-1's Avatar
Default Re: bluish smoke from start up (charger912)
so would that be valve seals i guess? i just pulled my plugs today and looks like in cylinder 3 is the one burning oil all the rest were fine
Old Apr 29, 2007 | 09:36 PM
doood's Avatar
been there done that
sounds like bad valve seals. oil is leaking past them into the cylinders when the engine is off. when you start it up it burns off that oil leading to the blue smoke.
Old Apr 30, 2007 | 09:18 AM
inspyral's Avatar
Have you done a compression or leakdown test?
user 98292739
Feb 21, 2005 12:01 PM
GocosblucivicSi
Nov 4, 2004 11:48 AM
T25So
Sep 8, 2004 11:39 AM
CivicBoi
May 27, 2002 11:59 AM
QuickHonda
Sep 21, 2001 01:19 PM
