Pinch Bolt Specifications
I threw my stock shock/springs on last weekend so I could send my konis to truechoice.... I was installing the front shock/spring assembly into the fork and began to tighten down the pinch bolt that holds the fork on. Well I guess the bolt had just about enough of being put in and taken back out because it gave up snapped off (i even used a torque wrench). Half the bolt is in there still (actually doing its job), though I think I can get it out.
Here is the question though... can anyone give me the specs for a front shock fork pinch bolt on a 2000 integra GSR? Tomorrow will by first (maybe only) chance to get the parts and work on it for a while.
Thanks in advance.
Thanks in advance.
Get a helms!
BTW if you are talking about the bolt that holds the shock tube it is a 10x1.25mm
if its the one holding the fork to the lower arm its a 12 x 1.25mm
chris215chris
Aug 17, 2003 08:18 PM
