b18ci custom turbo
b18ci custom turbo
Guys i need a little help here
want to use a t3 turbo off a saab, a intercooler off an eclipse.
MY question is this, the t3 has an internal wastegate, so where can i get a manifold so that it will all hook up?
Oil return will just be tapped into block, but where do i get oil feed?
can I safely run 5psi with just a vfac and stock fuel and injectors?
What other considerations am i missing?
Re: b18ci custom turbo (Audipwr1)
return goes into the oil pan, not the block...and you tee off the oilpressure sending unit for the feed. I would not recomend using an internal wastegate turbo...they suck. but if you must...you'll prolly find it cheaper to get a plate welded over the hole, and just use a DRAG/RevHard manifold
project dc2
01-22-2007 09:55 AM
project dc2
Northern California (Sales)
77
12-29-2006 09:22 AM
