(pics)what to do to b18b1 while its on the ground
Old Apr 24, 2013 | 06:11 AM
joes-92's Avatar
Default (pics)what to do to b18b1 while its on the ground
hey ht,
just picked up a b18b1 from the yard this past weekend. im slowly getting the missing sensors, gaskets, hoses/belts, bolts and such. is there anything that you would recommend i do before the actual swap? i dont have any large goals now, just want it running strong and reliable. the motor has 128k on it and ran fine before i pulled it(tested at yard). the 95 teg was totaled on the sides and rear and the front was clean.
as always, thanks in advance. now for the pics!
Old Apr 24, 2013 | 06:13 AM
sleepyaccord96's Avatar
Default Re: (pics)what to do to b18b1 while its on the ground
timing belt, water pump, camshaft seals x2, front crank seal, rear main seal, v/c gasket set with tube seals.
Old Apr 24, 2013 | 06:19 AM
how much did u give for the b18b1? i recently picked up a b20b4 for 250 with 110k
Old Apr 24, 2013 | 06:23 AM
joes-92's Avatar
$145 with alternator and military discount and $5 to have a fork tractor carry it to the truck. still missing the trans. it sucks because the the prices for b-series around here are sooo inflated. like an idiot, i left the fuel rail attached to the teg's filter. hopefully i can go back this weekend and grab it.
would you still replace tube seals if they look brand new? no oil on plugs as well. thanks for the parts list too!
Old Apr 24, 2013 | 06:30 AM
strategy400's Avatar
Rear main seal for sure. Anything that needs to be done to the transmission. Timing kit if you can get the pulley off. Oil pump maybe.
Old Apr 24, 2013 | 06:44 AM
joes-92's Avatar
man i love this site! thanks!
do these motors have multiple plug seals like the d series? ill prolly do all the gaskets under the vc. i should have my electric impact gun in the mail soon. im going to try it out when i do the timing belt.
for the cam seals, is that what that goop looking stuff is in pics 1 and 2? looks like a cap with liquid sealant.
Old Apr 24, 2013 | 07:14 AM
cam seals are located behind the cam gears that the belt rides on.
i dont see any goop you are referring to.
I myself cannot find a B series trans to mate with my b20b4, i need a 94 to 01 integra ls 5 speed trans and i refuse to spend 5 to 700 on one, they aren't worth that much. I sure wish i could find one for a decent price.
Old Apr 24, 2013 | 07:15 AM
and the tube seals i am talking about are on the underside of the valve cover, yes replace everything you can
Old Apr 24, 2013 | 07:28 AM
joes-92's Avatar
i know all to well about the trans... bad thing is, i cant offer lower when these high school kids around here will pay whats being asked.
the goop is actually on the dizzy side, on the end of the cam parallel. i guess thats not it though.
Old Apr 24, 2013 | 07:30 AM
joes-92's Avatar
i see those, but is there a lower seal as well? on my d15, i had 8 seals total(4 on underside and 4 under the rockers).
Old Apr 24, 2013 | 07:41 AM
Allboost18b's Avatar
send your head off and get it grinded down, cleaned, checked for leaks - most machine shops do it for like 90$ and it's a great Idea....
I have stock headers/downpipe for that if you need it - I ran them in my all motor b18b1 and they're coated all the way to the sensor.
Old Apr 24, 2013 | 07:42 AM
Also pm me what you need, I might have it. I have the LS non-vtec in my turbo civic swap. lots of left overs, and ECU if you need it.
Old Apr 24, 2013 | 08:02 AM
ok from what the OP is saying the engine is ok and runs fine. i would not remove the head and mill it and all that for no reason, The honda reliability fairy will exit the engine takin reliability with it, JUST KIDDING) but seriously i would just do routine maintenece, definately wouldnt take the head off for no apparent reason.
the goop the OP is referring to was probably to aid in sealing the VC gasket.
Old Apr 24, 2013 | 08:03 AM
joes-92's Avatar
converted the p75 a/t already and ill most likely end up doing aftermarket headers and downpipe. thanks and i will look it over, build a parts wish list and pm.
p.s. hhi huh? i just left mcrd(naval medical support) parris island last june. i miss it down there. didnt care to much for hh(loved the golf!)
Old Apr 24, 2013 | 08:48 AM
Marvin1985's Avatar
I have an ac compressor and pulley, also the t bracket. Pm me if you need or want em.
Old Apr 24, 2013 | 09:03 AM
joes-92's Avatar
no need for ac.lol. missing all the lines anyway. pm'd about bracket. what part of pa you from?
Old Apr 24, 2013 | 07:16 PM
I actually live in port royal moved here a month ago from HHI.
but i mean, hopefully the car runs "fine" tbh you said it ran.... not really knowing if its still A-ok.... I dont trust junkyard motors, just because it looks untouched doesnt mean that it has not been gone over; esp by the previous owner....
the head took me 20 min max to take off, with arp studs 2 days ago.... not a lot of trouble, you dont have v-tech....
its 14 cam cap bolts and 8 head bolts....
taking off 22 bolts, and payin the 35$ - thats for the head gasket, then 85$ for BnT (beaufort machine shop) to clean, check for cracks, and mill if needed - with pics to show they do great work....
to know what
A) your piston's and piston ring shape are in
B) if there's cracking/warping from running to hot or improper torquing from some past work
C) valve condition is, no leaking... they also clean the valves at most shops...
Idk I'd do all that before you put it in the car, ****, tbh idc what engine i buy and what shape its in, I always break it down and put all new bearings, all new gaskets etc in it on the major areas, just to know it was done correctly.
Old Apr 25, 2013 | 12:06 AM
Marvin1985's Avatar
Erie, north of Pittsburgh.
Old Apr 25, 2013 | 01:33 AM
HondaPartsHero's Avatar
Technical Hero
Only 4 tube seals
Old Apr 25, 2013 | 01:36 AM
jbpnoman's Avatar
That "goop" is Hondabond. Invest in a tube.
Old Apr 25, 2013 | 04:53 AM
to know what
I can see where you are coming from, but i only do it when needed, not everytime i get an engine
Old Apr 25, 2013 | 05:21 AM
nealnanoHX's Avatar
All this plus all rubber hoses, clutch, plugs, wires, cap, rotor, dizzy O-ring, exhaust cam seal the one on the trans side of the motor, clean the crap out the motor and engine bay.
Old Apr 25, 2013 | 07:57 AM
joes-92's Avatar
thats at the top of my list! i cant wait to hose that bad boy down. the bay is god awful fugly. i started stripping the vc for primer and paint last night.
also has anyone had any luck using the d series dizzy on a b18? i saw a couple of post that say it can be done with little mod.
Old Apr 25, 2013 | 08:15 AM
can you post pics of the car the engine is going in!
Old Apr 25, 2013 | 09:26 AM
joes-92's Avatar
here she is...
1992 vx, d15b7, 172k
purchased for $400 on 21feb13
most of it(including the engine comp) is the same way i bought it. the rims and 4 mismatched tires(17 or 16in, cant remember), f1 fenders and headlights came with it, as well as the hack job of a motor swap(seen in pics). the po decided to primer the engine comp and neglected to tape anything off. they painted over EVERYTHING including parts and the whole wire harness(s) i put 20% all around, new dizzy, wires/plugs, short ram, LED tails, 4300k ac 55w hid kit, new hu, auto locks and alarm, axles and yonaka catback with extra resonator, headers, coolant overflow tank, new temp sender & sensor, tstat, map sensor, ebay fogs(harness already fried). im sure i left some out. the dd/parts getter is the white dakota in the background and dont let the TN plates fool you.
