check engine light from retarding the timing???
Old May 19, 2006 | 02:33 AM
chirp2hrd's Avatar
Default check engine light from retarding the timing???
is it possible to get a check engine light from retarding the timing a little bit also now once in a while ill get a little hesitation sputter could this be what its from? when i turn the car off the light goes away
Old May 19, 2006 | 03:02 AM
__oversea's Avatar
Default Re: check engine light from retarding the timing??? (chirp2hrd)
did you pull out the code? what is wrong? there is trick you can do it DIY. get a paper clip and look under the passenger side under the glove box. there should be a plug that cover with green rubber. take it out and stick paper clip into both plug. then turn your key to NO. engine like will be blink . do a search for the code.
or you can just go to auto zone for free engine light check.
sorry for bad english.. just click this link
http://www.team-integra.net/se...ID=34
Old May 19, 2006 | 03:21 AM
integra3586's Avatar
Default Re: check engine light from retarding the timing??? (Last For One)
its hesitating because you retarded the timing. ud be surprised how much of a difference a few degrees makes
Old May 19, 2006 | 01:44 PM
chirp2hrd's Avatar
Default Re: check engine light from retarding the timing??? (B18B-SC)
ok i put the timign back to normal and reset the ecu and the check engine light is gone but once every couple hours it will sputter till i mash the gas it will liek hesitate.... could this be spark plugs, wire, or cap and rotor any other sugestions on what it might be
JDMJUNKIEMONKIE
Oct 22, 2009 09:24 PM
4WSLUDE93
Jun 5, 2009 11:24 PM
sleeperteg
Sep 29, 2005 06:45 AM
tuco_ruiz
Sep 15, 2002 05:24 PM
VTECVillain
Jan 6, 2002 11:40 AM
