performance gauges...how to hook up????
Old Oct 19, 2003 | 07:21 PM
teamhard2katch's Avatar
Default performance gauges...how to hook up????
sup fellow import racers? got a question.....just bought some gauges, i hooked up the volts, does ne one know how to hook up water temp. oil press, gauges??? ive been told i cant hook up the water gauge unlees i tap into the radiator,,i have a 93 civic d15....thanks...see u on the streets...
Old Oct 20, 2003 | 05:44 AM
PM-Performance's Avatar
Default Re: performance gauges...how to hook up???? (teamhard2katch)
this isnt drag racing related, but check out the instructions with the gauges, they are a great starting point
Old Oct 20, 2003 | 06:59 AM
Bnjmn's Avatar
water temp- you will need to tap into one of the smaller water lines like the one going to the IACV or from the throttlebody- get a 1/8" NPT brass tee and then a couple 1/8" barb connectors. Very easy just go to Home Depot for the tee/barbs and then a car parts store for the hoses
oil pressure- you will need the correct 1/8" BSPT fitting and then run a line from that to a 1/8" NPT tee. Contact Flamenco-T on this board and tell him what you are doing and he'll be able to sell you the correct parts.
Ben
FlewByU352
18
Jun 19, 2011 02:20 PM
TunerShark
Mar 1, 2007 03:41 AM
97AccordCD5
Dec 13, 2004 02:18 PM
SJR
10
Feb 12, 2003 07:52 AM
