which part do i need??
Old Jan 17, 2009 | 12:22 PM
kaj's Avatar
kaj
Default which part do i need??
here are pictures from under the car:
as you can see there is a t-fitting (3) that has no line on it. i dunno why. should there be something connected to it?
i also have a larger-dia, rubber hose that is hanging down from the top of the fuel tank. it has a quick-disconnect end on it and it goes nowhere. i have no clue where it should be going.
i no longer have the hard line that goes under the car to the evap canister. i'm guessing one of the lines i mentioned above, go to the front?
i have called two acura dealerships. nobody knows how this system should be set up.
please help. i want my EVAP system put back together!!
Old Jan 17, 2009 | 03:31 PM
ekb16's Avatar
Default Re: which part do i need??
in picture 1 the 2 hoses coming off the evap bypass valve, 1 hose goes to the fuel tank and the other goes to the charcol canister...i dont noe wut #2 is pointing to
in the 2nd picture nothing plugs into 3 that is the way it is suppose to be
Old Jan 17, 2009 | 10:09 PM
kaj's Avatar
kaj
just an open "t". oh. okay.
i have a rubber, corrugated line coming from the top of the fuel tank. anyone know what that goes too? it has a quick-connect fitting on it. i THINK it's supposed to hook up to one of the hard lines under the car, then to the charcoal canister?
Old Jan 18, 2009 | 05:34 AM
masterkill455's Avatar
yeah I would expect that line to run to a evap setup. The dealer should have access to a an emission hose diagram or evap schematic for you that will show you where it all needs to go but if not it should be in a chilton manual for your car
Old Jan 18, 2009 | 03:04 PM
ekb16's Avatar
i dont think i remember a quick disconnect on mine
johnnybbad08
Sep 24, 2008 11:42 AM
D16SohcVtec
Jun 27, 2008 07:01 AM
Homesickelian
Nov 18, 2006 09:55 AM
whiteturbohatch
Aug 16, 2005 01:01 PM
