Funky paint.
Old Mar 9, 2008 | 09:24 AM
JScott3d's Avatar
Default Funky paint.
I just finished painting the engine bay and it went well. After about 5 min after I had finished the paint started to look like shattered glass in some places and other places were smooth. I thought I did my prep right. FOr the prep I sanded it all down and the primed it and all went well. Then I wet sanded the primer in a couple of spots that needed it. At this point it was smooth and nice. Well I laid the color on and poof shattered paint. What would cause this? I have taken a couple of pics on the cell phone but they kind suck yet you can still see what I am talking about.
And is this savable or do I need to get some aircraft stripper and strip it. Then redo it from scratch?
Old Mar 9, 2008 | 11:38 AM
CE-CE's Avatar
well it does not need to be stripped but you will have to let it dry very good. then just sand it down untill fry marks are gone then put some sealer on the areas before you repaint it then after the sealer drys dust light coats of base on it then reclear it
Old Mar 9, 2008 | 08:47 PM
darklyte's Avatar
did you clean it before you sprayed it?
paint does that sometimes because of dust,dirt,or grease..
Old Mar 10, 2008 | 01:54 AM
T-Rock's Avatar
Its called lifting, usually happens when your topcoat doesnt get along with whats underneath it. Let it dry then knock it down with some 600 grit, seal it, then base it again and clear it.
Old Mar 10, 2008 | 03:25 PM
boost'd_crx's Avatar
Default Re: (T-Rock)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by T-Rock &raquo;</TD></TR><TR><TD CLASS="quote">Its called lifting, usually happens when your topcoat doesnt get along with whats underneath it. Let it dry then knock it down with some 600 grit, seal it, then base it again and clear it.</TD></TR></TABLE>
x2
Old Mar 10, 2008 | 05:21 PM
Genuine Rolla's Avatar
I also notice that lifting will happen if you let mixed paint sit for too long and it goes beyond its "shelf life"
Old Mar 10, 2008 | 09:23 PM
phatboycrxhf's Avatar
Default Re: (Genuine Rolla)
allso make sure you clean your gun very well before you load it .I forgot to when i sprayed my hood and i had lifting in a few spots ...so ghey ,i then wet sanded the base sprayed the area again and it was all good .
so it might be just your gun
sde780
Paint and Body
May 20, 2010 07:23 PM
sawjai526
Paint and Body
Sep 7, 2008 10:13 AM
rewerbcrx
Paint and Body
Feb 23, 2008 12:11 PM
Junglist
Mar 22, 2002 05:23 PM
