p72 chip in a p61?
Old Feb 14, 2004 | 12:12 AM
gutted's Avatar
Default p72 chip in a p61?
can it be done? are the electronics internally the same? chip is for an OBD1 p72 and i have a p61, 92 gsr. friends selling it cheap and i need to know if it will work or not.
Old Feb 14, 2004 | 01:01 AM
Katman's Avatar
Default Re: p72 chip in a p61? (gutted)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gutted &raquo;</TD></TR><TR><TD CLASS="quote">can it be done? are the electronics internally the same? chip is for an OBD1 p72 and i have a p61, 92 gsr. friends selling it cheap and i need to know if it will work or not.</TD></TR></TABLE>
you can technically run a P72 program on a P61 ecu, but the secondary butterflies will be inactive beacuse the motherboard on a P72 ecu is different than a P61 ecu, yet the programming is compatible between each ecu, its just that the P61 lacks the onboard hardware a P72 has -- and no, you cant add the P72 hardware to the P61 ecu.
Is the P72 ecu reprogrammed?
Old Feb 14, 2004 | 09:23 PM
gutted's Avatar
Default Re: p72 chip in a p61? (Katman)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Katman &raquo;</TD></TR><TR><TD CLASS="quote">its just that the P61 lacks the onboard hardware a P72 has -- and no, you cant add the P72 hardware to the P61 ecu.
Is the P72 ecu reprogrammed?</TD></TR></TABLE>
can you further explain the onboard hardware please, in dumb-terms? lol. and sorry if i didnt make it clear. i have a P61 ecu and a friend of mines has a chip for a P72 ecu. want to know if i can use it. any drawbacks with the secondary butterflies not working? will it affect anything else? thanks
Old Feb 19, 2004 | 04:21 PM
Katman's Avatar
can you further explain the onboard hardware please, in dumb-terms? lol. and sorry if i didnt make it clear. i have a P61 ecu and a friend of mines has a chip for a P72 ecu. want to know if i can use it. any drawbacks with the secondary butterflies not working? will it affect anything else? thanks</TD></TR></TABLE>
The P72 ecu has parts on it that allow it to operate the GSR's 2ndary butterflies, whereas the P61 ecu does NOT have these same parts to operate the 2ndary's at all. And you cannot take the parts off of a P72 ecu and add them to a P61 ecu to make the 2ndary's work because the P72 uses a completely different hardware than the P61 ecu altogether. The only thing that's compatible between the 2 ecu's is the programming (software).
Does that make better lamer sense?
Old May 26, 2004 | 06:03 PM
1's Avatar
Katman.... how about vice-versa? Can a Chip for a P61 be put in a USDM P72?
(the secondaries do not matter since it is a B16 head)
Thanks in advance!
Old May 27, 2004 | 10:47 AM
Katman's Avatar
Default Re: p72 chip in a p61? (1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1 &raquo;</TD></TR><TR><TD CLASS="quote">Katman.... how about vice-versa? Can a Chip for a P61 be put in a USDM P72?
Thanks in advance!</TD></TR></TABLE>
yes vice-versa will work and the 2ndary b-flies will be inoperable.
Old May 27, 2004 | 11:36 AM
Joseph Davis's Avatar
It's not difficult to add IAB functionality to a P61, if needed.
Old Jun 5, 2004 | 06:25 PM
JDMorgan's Avatar
some1 is selling a 92-93 gsr ecu on ebay and its a pg7, shouldnt it be a p61?
Old Jun 6, 2004 | 03:37 AM
Default Re: (KraZEtEggIE)
Yup. PG7 is 86-87 pre-OBD0 or 88-89 OBD0 Integra unit.
AlwayzSpoolin
Mar 29, 2008 10:24 PM
iH8RICERZ
Northern California (Sales)
Dec 9, 2005 12:04 PM
CA6VTEC
Apr 4, 2005 02:19 PM
plan B.
Mar 17, 2004 02:13 AM
