p28 ecu question.
Old Mar 27, 2005 | 09:00 PM
ALLMOTA92EG's Avatar
Default p28 ecu question.
im going to do a ls swap in my eg hatch and i was wondeing if i can use my p28 ecu since the motor i have right now is a single cam vtec and would i be able to use it since its a non vtec motor?
Old Mar 27, 2005 | 09:26 PM
Kendall's Avatar
The car will run, but it'll run like ****. You'll be throwing 2 codes along with not having correct fuel or ignition maps.
Old Apr 3, 2005 | 04:55 PM
92hatchZ6's Avatar
Default Re: p28 ecu question. (xthehardedgex)
na i dont think itll run like **** dont get me wrong you will throw 2 maybe 3 codes but itll run hard, my boy had a p28 in his integra ls and big difference from the ls ecu.
Old Apr 3, 2005 | 07:08 PM
PrettyLude's Avatar
how is the p28 gonna perform good on an twin cam ls, when the p28 is designed to run and have the right fuel maps for the single cam motor?
am i missing something here
Old Apr 3, 2005 | 07:21 PM
drdisco69's Avatar
Default Re: (PrettyLude)
Chip it and run anything you want. Disable VTEC while you're at it. http://www.pgmfi.org
Old Apr 4, 2005 | 02:45 AM
dragnsi's Avatar
Default Re: (drdisco69)
Hit this guy up for chips and info.
iH8RICERZ
Old Apr 11, 2005 | 12:58 AM
Joker1's Avatar
Look in http://www.Hondata.com It shows what ECU's **** with what car and what other ECU will work for that car...The P28 will work
HondaVTEC1993
Engine Management and Tuning
19
Apr 26, 2018 09:02 PM
evosix
Aug 26, 2016 04:37 AM
drewbie
Nov 30, 2007 07:09 AM
nota-eg
Jun 24, 2005 08:28 AM
Vtec92Civic
Oct 3, 2004 02:58 PM
