P28 dissy on a B16
Old Apr 19, 2004 | 03:39 PM
JonnyCoupe's Avatar
Default P28 dissy on a B16
Does the P28 SOHC VTEC dissy fit the B16 head at all? Even if its only 1 lug that lines up?
Are any dissy internals interchangable at all?
My goal is to run Hondata on my Pw0 equipped car, so i need to make the correct adjustments to the management system to do so
Thanks
Jonny
Old Apr 19, 2004 | 04:03 PM
DOHCtorTHRUST's Avatar
Default Re: P28 dissy on a B16 (JonnyCoupe)
i highly doubt it will work, the coilpack is at a different location and i believe that matters. however you can make a LS dizzy work, chop off one leg and it'll work just fine.
Old Apr 19, 2004 | 05:00 PM
VtecDeMoN's Avatar
Nope it won't work. B-series are not compatiable with d. It doesn't matter if 1 bolt lines up, the key fits into the cam differently. So no you can't use it.
Brian
Old Apr 19, 2004 | 05:48 PM
JonnyCoupe's Avatar
Default Re: P28 dissy on a B16 (VtecDeMoN)
Oh right.
I had tried my SOHC OBD0 D16 dissy in my B16 lump and that enagaged on the cam, just required one leg lopping off to clear the VTEC solenoid, was a while back now though so can't remeber the details fully.
Back to the drawing board i guess. We didnt get a non VTEC B series integra over here though.
Old Apr 19, 2004 | 06:06 PM
krazie1's Avatar
BANNED
yeah these guys are right
u can't use a single cam dizzy on the twin cam unless u do something if u lucky it can
if a 1st gen I got two that I have no need for
but obd1 and obd2 u should check out the classifieds
do it right don't try to cut corners
Old Apr 19, 2004 | 06:32 PM
JonnyCoupe's Avatar
Default Re: P28 dissy on a B16 (krazie1)
Thanks for the advice guys
Steven.
Apr 8, 2015 02:26 PM
Tyla12
Jun 30, 2010 04:14 PM
hellajdm333
Apr 28, 2010 04:15 AM
Sean5826
Jun 18, 2008 10:17 AM
H22A EG6
16
Jun 4, 2004 10:22 AM
