P0135 O2 Sensor Error
Old Oct 29, 2004 | 03:18 AM
rviray's Avatar
Default P0135 O2 Sensor Error
I have a post in the EG/EK forumn, but no responses...can anyone here help...
https://honda-tech.com/zerothread?id=1037563
Thank!
Old Oct 29, 2004 | 05:35 AM
JimBlake's Avatar
Default Re: P0135 O2 Sensor Error (rviray)
That's the heater circuit for the primary sensor. Since it's not showing any codes related to the actual sensor, here's what to check...
1 - Measure the resistance of the heater element. Across the 2 same-colored wires on the sensor. Should be between 10 & 40 ohms, & neither one should have any continuity to ground. If that's OK then your problem is in the car's wiring.
2 - One of the car's wires that connect to the heater should have battery voltage when the car's running. Maybe as soon as you turn the key to ON, I'm not sure...
3 - The other heater wire must go to the ECU. I don't have a wiring drawing for a '98 Civic, so I don't know which pin. Make sure that wire doesn't short to ground, because if it does, the ECU doesn't know that the heater's OK.
Old Oct 30, 2004 | 12:15 PM
rviray's Avatar
Thanks Jim...I will have to find someone better then me at wiring...I suck at it...Thanks
MugenHonda
Aug 5, 2014 05:47 PM
1992cxcivicEG
Dec 18, 2009 07:42 AM
R883
Jul 21, 2008 11:52 AM
vw eater
Jun 19, 2007 02:04 AM
maximedx
Mar 24, 2005 04:46 PM
