p+p and milling questions...
Old Oct 30, 2003 | 11:33 AM
ljoe's Avatar
Default p+p and milling questions...
i don't know much about headwork, but i plan on having some of it done, and with that said, i have a few questions. as far as port+polish goes, what is extreme and what is mild? and i know polishing helps flow more freely, but does it really make that much of a difference? also milling, what is a lot and what is a little?
Old Oct 30, 2003 | 04:03 PM
ljoe's Avatar
anyone?
Old Oct 30, 2003 | 07:51 PM
ljoe's Avatar
i know there are some damn smart people on here...
Old Oct 30, 2003 | 08:07 PM
Lord Helmet's Avatar
Default Re: p+p and milling questions... (ljoe)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ljoe &raquo;</TD></TR><TR><TD CLASS="quote">i don't know much about headwork, but i plan on having some of it done, and with that said, i have a few questions. as far as port+polish goes, what is extreme and what is mild? and i know polishing helps flow more freely, but does it really make that much of a difference? also milling, what is a lot and what is a little?</TD></TR></TABLE>
let's see, first extreme would be more benefical in a race setup and not in a daily driver setup. mild P&P is better for daily driver since all you're really doing is cleaning up and removing a little bit of rough surface in the ports of the head. for milling I wouldn't recomend milling the head more then the maximun factory specs since it seriously affect your timing. Once again that applies to a daily driver. for race setup that's another story. port and polishing is good for the head as long as you add other parts to go with the head ie...higher or lower compression piston, turbo, all motor setup, cams,etc...
petwhookie
Oct 10, 2007 01:18 PM
TeamSlowdotOrg
61
Aug 9, 2005 11:07 AM
Phil@SFP.net
May 17, 2005 06:24 PM
doubjj20
Apr 15, 2005 09:53 AM
Combustion Contraption
13
Feb 14, 2005 09:02 AM
