oxygen sensor problems. CEL 41.
Old Feb 21, 2008 | 12:21 PM
00fbp's Avatar
Default oxygen sensor problems. CEL 41.
quick history:
Bought a 00 civic dx hatch back in 2003.
Got out of the honda scene and used the car as a commuter car.
This year i have to smog the car to register and unfortunately CEL 41 shows up.
So i go to inspect the oxygen sensor and this is what i found.
</img>
</img>
and i also broke one of the bolts for the heat shield while trying to remove it.
</img>
The sensor is also stuck. I cant take it out.
My question is:
Is the crack in the manifold causing the code 41?
Will the CEL go away if i just change the sensor?
Do i have to buy a whole new manifold and cat?
Thanks in advance guys.
Old Feb 21, 2008 | 01:25 PM
Totall Insane's Avatar
Default Re: oxygen sensor problems. CEL 41. (00fbp)
u defitintely need a new manifold. if u replace the o2 sensor it'll go bad again.
does ur car deposit alot of carbon through the exaust and burns lots of fuel?
Old Feb 21, 2008 | 02:09 PM
00fbp's Avatar
Default Re: oxygen sensor problems. CEL 41. (Totall Insane)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Totall Insane &raquo;</TD></TR><TR><TD CLASS="quote">u defitintely need a new manifold. if u replace the o2 sensor it'll go bad again.
does ur car deposit alot of carbon through the exaust and burns lots of fuel?</TD></TR></TABLE>
i just need to get rid of the CEL for now so i can smog it.
Do you think crack will make the car fail the smog test.
sorry for all nooby questions.
Old Feb 22, 2008 | 12:08 PM
starchland's Avatar
chances are the crack isnt making that happen,unless air is getting out of it, which it doesnt look to be big enough...its probably just a worn o2 sensor. however you may want to replace it for piece of mind with something aftermarket that is stainless steel...would probably be cheaper too. I dont know how it works in your area, would they consider this crack a safety issue or something.
santanach
May 19, 2008 04:02 PM
00fbp
15
May 6, 2008 07:02 AM
DAP97SI
15
Jan 15, 2008 10:52 PM
Rubixcu7
Aug 18, 2005 12:51 PM
