overheating....perhaps air in cooling system?
Old Aug 2, 2002 | 05:15 PM
GruvyTune's Avatar
New User
Default overheating....perhaps air in cooling system?
please help.
I have 9:1 pistons now and I find that with the ac on i get a definite power loss compared to when i was a stock engine. car pulls fine once it gets going but the load definitely seems higher than before. and when i come to a stop the car idles down really low (even stalled a couple of times) and then comes back up to normal steady idle.
Old Aug 2, 2002 | 05:42 PM
Sonny's Avatar
Default Re: overheating....perhaps air in cooling system? (GruvyTune)
Backfill the cooling system, Torin. Works for me. I've never had an overheating problem by doing it this way.
Sonny
Old Aug 2, 2002 | 06:37 PM
GruvyTune's Avatar
New User
Default Re: overheating....perhaps air in cooling system? (Sonny)
sonny,
where should i fill from? do i have to empty everything to do this? does it have to be done under some pressure?
Old Aug 2, 2002 | 10:20 PM
Sonny's Avatar
Torin,
The way I do it is to hook everything up and then disconnect the upper radiator hose from the top of the radiator. Then pour the water/coolant mix into the hose so that it 'backfills' into the engine that way. I can usually get about a quart or 2 in there before it starts to come out of the hose. Then I plug the hose back into the radiator and fill up the radiator.
I had to this about 10 times (don't ask why , boost ) during the time that I owned my Civic Si and I never once had an overheating problem.
Sonny
19992civichatch
Mar 1, 2007 10:49 AM
jdmkid_82
Jan 2, 2007 10:08 PM
-Championship-
Nov 26, 2006 07:14 PM
chriseg6
Honda S2000
Sep 23, 2006 11:48 PM
mario82686
Apr 13, 2004 12:47 AM
