Honda S2000 Honda S2000
radiator problem
Old Sep 23, 2006 | 03:29 PM
chriseg6's Avatar
Default radiator problem
My radiator keeps spitting the coolant back into the reservoir tank...then it shoots out all the coolant...what should i do?
Old Sep 23, 2006 | 05:22 PM
WowOzYouRock's Avatar
Default Re: radiator problem (chriseg6)
are you over heating?
Old Sep 23, 2006 | 06:16 PM
chriseg6's Avatar
Default Re: radiator problem (FR-MOB: Jerk)
yea the temp goes up...
chriseg6's Avatar
the main hose tightens like its sucking air and then it all pressured up
Old Sep 23, 2006 | 07:21 PM
kane.s2k's Avatar
how many miles on the car?
Old Sep 23, 2006 | 09:43 PM
chriseg6's Avatar
Default Re: (kane.s2k)
15000...it starts heating up when i turn on the heater and the air doesnt get hot....i think the thermostat might be the problem but i dont kno....
Old Sep 23, 2006 | 10:07 PM
Default Re: (chriseg6)
check thermostat or water pump ....
Old Sep 23, 2006 | 11:48 PM
kane.s2k's Avatar
Re-fill the coolant system and bleed the system correctly. Completely cold engine with the heater on and blowing (keys turned but not the engine). Open the bleed screw on the intake manifold (12mm) and the little rubber plug that's on the heater line on the firewall right above the engine. Begin filling the system from the radiator. Once you have coolant pouring out of the bleed screw, close it and fill up the radiator to the top and put the cap back on.
Start the engine and let it run for about 20 seconds. Shut it off and open the cap and see if it needs to be filled some more. Add enough fluid to the reservoir to be at the min line.
You probably had a bunch of air in the system. If it just started to do this out of no where, it's probably something in your system that's failed - cap, thermos, water pump.
snowblind7x
May 21, 2009 12:28 AM
Shintakun
Honda Civic (2001 - 2005)
Jan 26, 2008 07:44 PM
kjkhemraj
21
Jul 24, 2007 11:54 AM
wld2rde
Feb 10, 2005 05:54 AM
dbailey
Nov 21, 2004 12:34 PM
