Ordering from HMOTORS, replacing parts?
Old Oct 8, 2009 | 06:49 PM
FlewByU352's Avatar
Default Ordering from HMOTORS, replacing parts?
"Start up warranty is only valid on USED, JDM & USDM motors and is unconditional when changing the following engine components:- spark plugs, spark plug wires (leads), rotor, timing belt, water pump and tension pulley. All of the previously mentioned have to be changed on JDM & USDM motors to become legible for the 100% start-up warranty."
I was told by a friend that they usually just change out the timing belt and water pump. Is the rest really needed? I dont want my new motor to fail so I want to do it right. Spark Plugs, Spark Plug Wires, Rotor, and Tension Pulley is that something I should do? How much will that cost for a B18C5?
Old Oct 9, 2009 | 04:01 AM
kyden's Avatar
Default Re: Ordering from HMOTORS, replacing parts?
its something you should do with an unknown motor anyway. its about $100 if you use ngk wires and plugs with oem cap and rotor.
eddie7978
Dec 21, 2017 03:08 AM
hondur
Jan 16, 2017 09:58 AM
LDForget
Honda CR-V & Element
11
Oct 15, 2012 11:11 AM
ArithMEHtik
Aug 15, 2011 10:58 AM
imported204
Apr 27, 2002 11:23 AM
