onNew Brake Master Cylinder
Old Nov 20, 2003 | 09:07 AM
CrXstEalin's Avatar
Default onNew Brake Master Cylinder
Could somone give me the run through on how too install?
Old Nov 20, 2003 | 11:01 AM
poison's Avatar
Default Re: onNew Brake Master Cylinder (CrXstEalin)
Remove the two 12mm bolts, remove the two brake hydraulic lines. Bench bleed the new M/C, and reverse the order and bleed your brakes.
The order for bleeding brakes is:
Rear Passenger
Front Driver
Rear Driver
Front passenger
Old Nov 20, 2003 | 03:39 PM
smeister's Avatar
Default Re: onNew Brake Master Cylinder (poison)
I always thought it was start from furthest away from M/C and work your way closest?! Can someone clarify this?
Old Nov 20, 2003 | 10:12 PM
mycivicstoo(s)low's Avatar
Default Re: onNew Brake Master Cylinder (smeister)
Is it neccessary to bench bleed the new master cylinder?
EDIT: After searching, it appears that it is.
Modified by mycivicstoo(s)low at 3:02 AM 11/21/2003
Old Nov 21, 2003 | 04:33 AM
JimBlake's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by smeister &raquo;</TD></TR><TR><TD CLASS="quote">I always thought it was start from furthest away from M/C and work your way closest?! Can someone clarify this?</TD></TR></TABLE>That's old school. The bleeding order depends on which circuit is likely to push bubbles into which other circuit. With different ABS systems they all have different bleeding orders - check a Helm book for YOUR car.
But I think if you bleed the wrong order, the only problem is you might have to go around a couple more times before all the bubbles are out.
5rivers
Oct 10, 2015 06:44 AM
justforkicks
Sep 10, 2006 11:47 AM
crx00
May 30, 2005 08:45 AM
I_love_my_HONDA
Apr 24, 2005 07:34 AM
GReddy SI
Jul 17, 2003 09:36 PM
