Oil in the spark plug holes
Old Apr 24, 2011 | 09:03 PM
notnilc20's Avatar
Default Oil in the spark plug holes
Changing my spark plugs and wires on my new (used) '96 Acura 2.5TL today and all but one spark plug hole was drenched in oil. Not just the Spark plug area but on the boot of the wires as well...made me sick.....what can I do to stop this?? Please help...I have pretty good mechanical ability but am not familiar with this area. Thank you.
Old Apr 24, 2011 | 09:52 PM
kpjo4's Avatar
Default Re: Oil in the spark plug holes
remover ur valve cover and see if it has o rings as a gasket around the sprak plug holes between the valve cover and head.
Old Apr 24, 2011 | 10:32 PM
wc4ohio's Avatar
Valve cover gasket kit... it comes with the spark plug hole o-rings, just make sure you clean the mating surface of the valve cover good first and torque it to specs when you reinstall it.
Old Apr 24, 2011 | 10:37 PM
notnilc20's Avatar
Thanks all....I'll try this tomorrow.....
Old Apr 26, 2011 | 03:23 PM
spcrxracer's Avatar
maybe this will help. I know the engine is different in this video, but are there 2 sets of o-ring gaskets?
http://www.youtube.com/watch?v=wYU8qtPzQOY
Old Apr 26, 2011 | 06:49 PM
notnilc20's Avatar
hey there again....yeah, I did what is in the video and got to the o-rings underneath the rocker arm assembly and they definantly needed changing....however, what the heck are the O-rings called? Everytime I try to find these people just offer me the ones that go in the Valve cover. So to recap I'm changing the Valve cover gasket, the spark plug tube seals (located in the Valve cover), and the o-rings located in the spark plug tube underneath the rockerarm assembly.....what are they called so I can order them? Thanks.
foxfai
Mar 31, 2009 08:03 AM
t0kyoStatus
Nov 26, 2008 07:05 PM
skaternak
Oct 2, 2008 10:32 PM
Dj Skidz7
Apr 29, 2008 11:16 AM
sahtt
Aug 4, 2007 01:59 PM
