oil on spark plug
Old Jan 7, 2003 | 06:51 PM
insomniac791's Avatar
Default oil on spark plug
Today I was going to do a tune up and when I took out my #3 and #4 plug there were soaked in oil. But the oil was all over the threads. My car does not smoke at all so I called my mechanic and he said it was my valve assembly or something like that he said he would also adjust my valves and change my valve cover gasket and the spark plug gasekt for $275.00 and he said that should fix it. What do you guys think? it a 91 CRX Si.
Also it has a loss in performance and bad gasmilage?
later
MAtt
Old Jan 7, 2003 | 07:53 PM
RAWB's Avatar
Default Re: oil on spark plug (insomniac791)
$275!!!
That should be illegal. Get a manual and do it yourself. The gaskets will run you about $15 for the valvecover and $3 ea. for the sparkplugs.
A Valve adjustment is easy, as well- do a search there are plenty of step-by-step instructions to guide you through, if not I'll show you a great one.
For Real, save your money... GL.
108Mdx
Mar 26, 2015 01:51 PM
premo_si
Jan 23, 2008 08:57 PM
Saki
Mar 4, 2005 06:20 PM
cxVtecC1
Jan 16, 2005 05:00 PM
mailforjon
Aug 5, 2002 04:34 PM
