oil pump interchangeability
Old Mar 23, 2008 | 11:25 AM
stockbee's Avatar
Default oil pump interchangeability
what's up guys? I figured I would ask you all this ? before I did it anyway.
I'm freshening up a B16A and I would like to change the oil pump and water pump out for peace of mind. The only problem is that I have a brand new oil pump and water pump downstairs in my tool chest for a GSR.
I counted the teeth on the water pump and they are the same so I know I can use that wihtout a problem. What I don't know for sure is if I can use the P75 oil pump on the B16A without having a problem. They both work in lubricating VTEC engines but I just wanted to double check with people that are smarter than me and are more experienced.
Thanks.
Old Mar 23, 2008 | 03:53 PM
stockbee's Avatar
Anybody have a clue? bump for some aid in this area.
Old Mar 24, 2008 | 09:15 PM
inspyral's Avatar
Are they the same OMD generation? I believe OBD-II pumps have the crank sensor built into the oil pump, while earlier generation pumps did not. Other than that, I don't see why you couldn't interchange same-generation B series VTEC pumps.
Old Mar 25, 2008 | 06:24 AM
stockbee's Avatar
yes I have the one without the crank sensor.
Old Apr 13, 2008 | 12:33 PM
g2daturbo's Avatar
Default Re: (stockbee)
both exactly the same.... slap it on and call it a day... have done this exact thing many times before!
93HatchDreams
Jun 30, 2014 03:35 PM
SpoolnG2
Apr 1, 2008 06:15 PM
stockbee
Mar 25, 2008 06:26 AM
zCivic
May 22, 2003 04:41 PM
Gonzo
Feb 14, 2002 12:57 PM
