Oil Pump
Old Feb 14, 2003 | 09:20 AM
Irate's Avatar
Default Oil Pump
Will turning the motor over by hand still pump enough oil to lubricate the crank? I dont think it will but just want to be sure.
The motor will sit for a while and just had new bearing put in it. I dont want to turn the motor over if they dry out.
Old Feb 14, 2003 | 10:23 AM
VTECLVR's Avatar
Default Re: Oil Pump (Irate)
if there is oil in the motor it should be ok to turn. also hope you used pre-lube on the bearing when puttng the bearing back in.
Old Feb 14, 2003 | 10:30 AM
Irate's Avatar
Default Re: Oil Pump (VTECLVR)
Yeah I pre lubed every bearing half before installing. Just didnt know if the pump would pick up oil and feed the crank turning that slow.
[Modified by Irate, 7:31 PM 2/14/2003]
DC4R27
Jan 28, 2007 12:20 PM
slipperyduck
Feb 16, 2006 09:52 AM
sleepyhatch00
Sep 2, 2005 01:35 PM
dbang003
Oct 21, 2004 05:31 PM
Lei Siew Long
Apr 17, 2002 08:54 PM
