Oil Pressure Sensor broke in block, why? (pics)
Old Aug 29, 2008 | 10:45 PM
VT VTEC's Avatar
Default Oil Pressure Sensor broke in block, why? (pics)
Had an oil pressure sensor snap in a Honda B18C block tonight while driving around. Possibly due to a bump on Interstate 64. It is a pretty standard aftermarket (brass?) fitting for an aftermarket gauge, not OEM piece. Broke right at the outer edge of the block. A thin metal ring clung to the brass also (pic attached). I certainly don't want this to happen again, anyone got a theory as to why it would snap? Pics might have clues:
Old Aug 30, 2008 | 01:51 AM
Flashmn's Avatar
Default Re: Oil Pressure Sensor broke in block, why? (VT VTEC)
Weight of the sender, thats such a common mistake people make. You need to use a teflon etc hose and mount the sender on the frame of the car.
Old Aug 30, 2008 | 03:49 AM
non-VTEC's Avatar
yup....never use a brass fitting to mount the sending unit to the engine. it will brake off just like that.
use a extractor to pull the bit out and hopefully the threads will be ok.
Old Aug 30, 2008 | 05:24 AM
VT VTEC's Avatar
Ah, ok. Fitting I'm not worried about. Motor, I am.
Old Aug 30, 2008 | 09:22 AM
VT VTEC's Avatar
Default Re: (VT VTEC)
I've also been told it could be an over-tightening issue, which might even have caused a tiny fracture. It only lasted 160miles on the car. Is there a way to tell the difference?
Old Aug 30, 2008 | 10:00 AM
Flashmn's Avatar
its the weight, trust us on this. Overtightening cracks the block.
Old Aug 30, 2008 | 11:02 AM
mtber's Avatar
Default Re: (Flashmn)
Don't use brass oil fittings...
Next time run an alloy fitting to a 3an line to a mount location.
Google.com - easy out
Old Aug 30, 2008 | 02:47 PM
1992Si's Avatar
I'll agree it's the weight. Get rid of the OEM sensor and put a direct reading gauge in the car.
Yes the brass fitting doesn't need to be to tight.
There's how I normally run the oil feed and the shut off valve about 1/3 open to cut down oil pressure. Notice the 1/8" copper line for the gauge.
Old Aug 30, 2008 | 04:03 PM
VT VTEC's Avatar
Default Re: (1992Si)
Forgot to add, the fitting was placed/removed 2-3 times during the motor build. Originally placed by the builder of the car, then removed and replaced once or twice by the tuner. That would certainly cause stress.
I don't understand why a well-known Honda tuner would put this in the block without saying anything or suggesting an alternate. Must have thought it was safe?
I'll certainly have it relocated now.
mmmbarp
11
Feb 19, 2012 04:00 PM
KooK
Nov 26, 2005 05:29 PM
...me0w
Jun 24, 2005 07:01 PM
turbotime
Nov 29, 2003 04:58 PM
