oil pressure sender unit size..
Old Jan 12, 2003 | 07:59 PM
MeanGreenEG9's Avatar
Default oil pressure sender unit size..
Do all B-series blocks use the same oil pressure sender units? I think I have one in my b16a that is too big for mine... but not sure..
Old Jan 12, 2003 | 11:09 PM
B18EG6's Avatar
Default Re: oil pressure sender unit size.. (SlowAssB16a)
Why do you think it is too big? does it not fit into the threads on the block?
Old Jan 12, 2003 | 11:11 PM
simple4012's Avatar
New User
Default Re: oil pressure sender unit size.. (B18EG6)
1/8. they alll the same
Old Jan 13, 2003 | 12:16 AM
B18EG6's Avatar
Default Re: oil pressure sender unit size.. (simple4012)
correct. Dont forget to mention 1/8" bspt
Old Jan 13, 2003 | 11:15 AM
Well i have a feeling that oil is leaking from where it threads intot he bolt.. plus the unit doesn't screw all the way into the block and it kinda leaves a small gap.. how much are you supposed to torque it?
Old Jan 13, 2003 | 02:00 PM
Chiovnidca's Avatar
13lb-ft. Use a little Hondabond on it.
stocker2shocker91
Aug 22, 2009 09:52 AM
RedPinoySi
Jun 12, 2007 05:23 PM
NoVALude
May 9, 2006 06:12 AM
b18cvtec
Jun 8, 2003 10:57 AM
90TegRex
May 19, 2002 04:22 AM
