OIL Pressure gauge?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Super_Eg6 »</TD></TR><TR><TD CLASS="quote">I in search of a new oil pressure gauge...does anyone have any suggestion...should i get a machnical or electrical?</TD></TR></TABLE>
Autometer mechanical gauge w/ a copper oil line.
i have a "t" for my LSV oil line...BUT if i have a 3 way joint for oil-line, oil-pressure sensor (oem) and a line for the gauge, will all these connections affect the acutal pressure for the gauge...???
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Super_Eg6 »</TD></TR><TR><TD CLASS="quote"> i have a "t" for my LSV oil line...BUT if i have a 3 way joint for oil-line, oil-pressure sensor (oem) and a line for the gauge, will all these connections affect the acutal pressure for the gauge...???</TD></TR></TABLE>
no they wont.
no they wont.
i advice against putting all those connections on the stock oil pressure switch location on the block.they could easily rattle itself out.
they sell distribution blocks, so just run a line to that.
you can take the stock sensor out since you have a aftermarket pressure gauge
be careful when using copper tubing on mechanical guages. mine broke at the fitting going into the gauge and leaked all out inside my car. Luckily i caught it and stopped it up. A few days later it started to leak at the fitting on the back of the block and I was down a qt and a half
the copper tubing gets fragile with the pressure fitting on it inside the screw on brass fittings so be careful
yes i found out that golden eagle has a better one than greddy....group buy is cheaper too...my friend had a greddy one but our local hot rod shop that seems to have all the fittings in the world could not find one that fits so when we calleda GREDDY distbutor, they said they have no idea what the size was, only that it fits the greddy gauge adaptors...
fryman
Aug 26, 2009 10:42 PM
