Oil press. light is on??
Old Jan 5, 2003 | 05:47 PM
quik2kSi's Avatar
Default Oil press. light is on??
i just recently took out my Autometer oil pressure gauge and put the factory oil press. switch in there and i just noticed that when the key is "on", (car not started) that the oil press. light is on. when i start the car the light goes off... i'm guessing it is no big deal considering i am getting press. because i am able to run v-tec, but why the hell is the light on? anyone else's do this?
Old Jan 5, 2003 | 07:21 PM
MattG's Avatar
New User
Default Re: Oil press. light is on?? (quik2kSi)
Its like that on most cars. The light is on so you know the bulb works.
Old Jan 5, 2003 | 11:20 PM
94TealGSR's Avatar
Anyone? Try "Everyone".
Old Jan 6, 2003 | 01:29 AM
b19coupe's Avatar
When the car is not started you have no oil pressure, so oil pressure light is on. Start car, oil pressure builds up, light goes off.
Old Jan 6, 2003 | 01:10 PM
quik2kSi's Avatar
Default Re: Oil press. light is on?? (94TealGSR)
No...not everyone! If my friends B20/Vtec did this i would not be asking. And he still has the factory oil press. switch. In fact, his isn't even connected directly to the block. It is connected to a rubber hose which is connected to a fitting on the block.
Old Jan 6, 2003 | 01:42 PM
Kamin's Avatar
yes
EVERYONE
the oil pump only pumps when the engine is running, its not electric like the fuel pump.
so when you turn the key to II there is no oil pressure so the light goes on, when the car is started, it goes off.
your friend probably had a burnt out light.
Funkin Flux
Mar 17, 2006 10:12 PM
notstock93
Dec 23, 2004 02:13 PM
tl
Jul 27, 2004 11:58 PM
PokeyD16Z
11
Jul 7, 2004 11:39 AM
IH82LOSE
Jan 4, 2004 05:16 PM
